Question about Dynex 32 in. LCD Flat-Panel HDTV
Power went off. power back on but tv will not come on. like it is not getting power. checked power source. reset button?
    Problem Solver:
  • 14 Answers
Ok this is NOT really truly a solution but more of a '**** it & see' but it's what i have 2 do with my sony.......
Mine does the same think i.e. i turn it on & there's power but just the stand-by light so I have to use the remote & hit the source button continually really fast about 10 times then pause about 3 seconds then do it again it takes quite a few goes but it does work
but please try at your own risk (i've been doing this for about 3 months now cos the repair cost is too high!!)
Posted on Sep 06, 2010
  • dehowletts
    dehowletts Sep 06, 2010
    i wrote **** it
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
Mar 02, 2015 | Televison & Video
Locked tv trying to turn on to hdmi now have mayby hotel lock on
you have to somehow reset the tv, something like hold the power button for 30 seonds or maybe stick in a usb with a tv software program from mft so it knows to reboot from that usb source, or even the entire chip on the main board using the usb method- check with mfr
Dec 04, 2011 | Philips Televison & Video
I purchased viewsonic N3251W. It worked fine for 2 years. then its power supply board damaged. I replaced it with exact part but now i am unable to change input source. By default its inpur source is set...
hi;
please check the connectors of power supply board, and reset all connectors.
if you have digital or analog tester,try to read the output voltage of the power supply
http://www.youtube.com/
maybe no +5v going to mainboard..
or check the front panel board if its properly connected to mainboard.
thanks....give some comment so i can help you more....
Sep 14, 2011 | ViewSonic N3251w 32 in. LCD HDTV
My sound on the TV just went about a week ago and i cannont get it back for some reason. Everything else is perfect so I dont know what is wrong with it?
Check your TV may be set to Auto SAP in the MTS feature. Make sure the speaker option is set to On in the Audio Menu. Or Reset in Factory setting> Turn on the TV. While holding down the RESET button on the remote control, press the POWER button on the TV front panel.The TV will turn itself off, then back on again. Release the RESET button.
Jun 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My StreetPilot c330 ( 4 years old ) went dead and I can not get it to come back on. I have checked the fuse and pushed the reset button.
PULL OFF SILVER FACEPLATE AND A RESET BUTTON IS BEHIND FACE PLATE COVER PLUG UNIT UP TO POWER SOURCE PRESS RESET BUTTON AND THEN PRESS POWER BUTTON,YES BATTERY MAY BE DEAD BUT AS LONG AS YOU KEEP CONNECTED TO A POWER SOURCE IT WILL WORK.
MINE DID THE SAME THING I JUST KEEP CONNECTED TO CIG ADAPTER IN MY CAR.
Oct 25, 2009 | Garmin StreetPilot C330 GPS Receiver
My 6 month old tv went out during a movie we were watching and when i turn it back on all i get is a blank black screen. what do i do? It is a 42" Element
Hi Chris!
Please disconnect all the cables from the TV then reconnect them back after two minutes. Make sure that the power cable from the TV is directly connected to a functional wall outlet. Next, turn ON the TV and reset it to the original factory settings. You may also try connecting a different video source such as cable box, DVD player, Blu-Ray player, Playstation, etc to the TV to check whether the issue persists with all the video sources.
If the issue persists with all the video sources then service may be required.
Jul 12, 2009 | Televison & Video
I have just been given a Samsung sp42w4hb back projector TV that has a problem,after about 4 power cuts in the area the TV went off and only the standby light comes on,it stays on for about 10/15 seconds...
check to see if you have a loose conection at the relay or at the power source a lot of times the relay goes bad and you can solder a neew one in get a service manual to locate relay and parts
Jan 21, 2009 | Samsung Televison & Video
Picture and no sound
Check to source of power to TV. These unite's are very sensitive to changes in power. If it isn't get the proper power, it can effect the TV output. Computers are very sensitive to power fluctions and should be connected thru a battery backup, so that the power going to the sensitive electronics is filtered to prevent surges from effecting the output of the electronc device. It could be a microwave, refrigerator, Tv anything having electronic conponets.
Apr 08, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Viewsonic vpw 505 won't turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Mar 06, 2017 | ViewSonic VPW505 50 in. HD-Ready Plasma...
Dynex 32 in. LCD Flat-Panel HDTV Logo
89 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
