Question about Panasonic CT-36SL13 32" TV
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi tnt_guy, I was wondering if you could help me about this fuse problem I keep having. The original fuse, I think it was a 5.6A blew when the TV was not even 4 yrs old, last fall. I could not find a 5.6 so I bought a couple of 6A fuses. All was good until about a month later it blew the new one. To keep the story short, since then I replaced it already about 6 times in less than 6 months. Panasonic is referring me to a repair shop, which wants too much to come out and look at the TV.
My question is, would the .4 A difference make much of a difference and be the reason for such frequent fuse replacement need?
My other question is what could be the reason for all this.
I really appreciate your help.
Thank you,
Mendi.
  • mendiv May 22, 2008
    Thanks. I would take it in, but it weighs about 1000 lbs.
    I'll just have to live with it for a while.
  • 35 Answers
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
Posted on May 13, 2008
Lights keep blinking
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
How to install HID Xenon kit with Anti Flicker Capacitors Error Code...
Motorcycle LED Turn Signal Flasher Relay Blink Rate Fix Honda
https://dl.dropboxusercontent.com/u/35177464/TNT/1130/TnT%201130%20Workshop.pdf
https://dl.dropboxusercontent.com/u/35177464/Benelli/Cnunes%20Manuals/TNT1130%20Parts%20Manual%20-%20Cnunes.pdf
https://dl.dropboxusercontent.com/u/35177464/TNT/1130/TnT1130%20Owners%20Man.pdf
Aug 04, 2014 | Benelli TnT 1130 Motorcycles
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
Tv went dead
Sounds like it could be H.O.T which stands for horizontal output transistor or a fuse is possible. Another possibility is the FLYBACK transformer. Is there a local repair facility you could take it too? Keep me posted. Have a good day...Jay
Feb 01, 2008 | Panasonic CT-36SL13 32" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
The tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Aug 14, 2007 | Sylvania 6432GG 32" TV
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Panasonic CT-36SL13 32" TV Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
