Question about Mtd Garden
Mower deck shakes when PTO is engaged - Mtd Garden
  • 183 Answers
An imbalance is causing your vibration. check the blades. You probably have a bent or damage blade. Could also be a bad spot on the deck belt or a damaged spindle.
Good luck.
Posted on Sep 07, 2010
I have a John deereL130, deck rusted so I got one from a JD L100 it has a manual pto lever to engage, but my L130 is electric pto.it mounted easily,do I need to add tensioners to deck for it to work
On the electric clutch method the belt from the engine pulley to the deck pulley is tight all the time, yes it normally has a idler pulley with a spring to keep it tight. The spring is needed so do not omit it and lock it solid or it will shake itself apart. Hopefully you can copy your L130 deck as well as use the idler and spring from it.
Apr 29, 2016 | Garden
JD 1026R tractor. Why the PTO does not work?
many of this type machine will not engage the PTO if the battery is not full charged or bad
Apr 17, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
Why can't I engage the mower deck?
Riding Mower Electric PTO Clutch Won't Engage When Hot ...
? 7:16
www.youtube.com/watch?v=wH9tZl6GzE0
May 2, 2014 - Uploaded by Steve O The PTO is relatively easy to change assuming that you can get the bolt out of the crankshaft. Basically follow ...
Sep 09, 2015 | Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Craftsman mower deck engaging intermitantly
I believe I would start by looking at the grounding for the solenoid(clutch) sounds like that it may be intermittent. Or the spring assembly that physically engages the assembly on the deck my be dirty or need a lubricant and a cleaning or both. Good Luck
Jun 04, 2012 | Garden
Pto not engaging in john deere lx 167
Check the voltage on the wire(s) connector to the PTO switch. Sometime portion of the switch can go bad. If you have voltage coming in to the switch check the output voltage going to the clutch..
Apr 03, 2012 | Garden
John Deere 160 Mower Deck Switch - mower deck does not engage when switch is turned on. The "dead man" engine shutoff still functions when the switch is engaged - if the switch is on and there is...
Hi, check that you have 12 volts to the pto when the switch is on. It sounds like your pto is fried as the switch is functioning correctly. Regards Phil.
Sep 20, 2011 | John Deere Garden
Garden Logo
626 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
