Question about ViewSonic ViewMate Keyboard
Wireless is off. Pressing F2 doesn't turn it back on . How do I turn on wireless?
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
How do you turn on wifi for dell latitude d610
There is not wireless switch on this model. To turn on your wireless you will need to hold down FN + F2. If this does not turn on your wireless its most probably disabled in the Bios. To enable it, press the F2 key at the Dell Logo on startup, move down to wireless, press enter and move to wireless control, make sure its set to Fn+F2/App, then move down to wireless devices and make sure it set to on. Press Esc, and save changes and exit.
Sep 08, 2011 | Dell Latitude D610 Notebook
Wireless capability Switch is off on dell vostro 1400.Is there another way to turn on switch.
There are three ways to toggle the wireless switch on/off, 1st, Fn + wireless button (F2 or F5), 2nd, the wireless switch on the side of the laptop, 3rd, it can be enabled or disabled under BIOS setup (Tap F2 when turned on the laptop).
Jun 30, 2011 | Computers & Internet
Dell inspiron 6400 wireless capability turned off. need to find switch or function key combination
Hi, How do u do? You can easily turn it on by pressing Fn + F2.
have nice day. Babak
Mar 13, 2011 | Computers & Internet
Can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Dec 12, 2009 | Dell Inspiron 6400 Notebook
Wifi will not turn on
Try pressing FN & F2 at the same time it will enable the wireless. Also reboot the pc press F2 when you see the dell screen and make sure wireless is set to on.
Dec 01, 2009 | Dell Latitude D610 Notebook
What is the function key used to reset/turn the wireless on; the wireless light is on, but my wife's computer keeps telling her to turn on wireless capability and WLAN disabled. We use a wireless router (I...
tHE COMBINATION IS THE FUNCTION KEY AND THE F2 BUTTON TO TURN OFF AND ON THE WIRELESS. HOLD DOWN THE FUNCTION KEY WHILE PRESSING THE F2 KEY... HOPE THIS HELPS
Jun 09, 2009 | HP Pavilion dv4-1145go Notebook
Where is the wireless button on t42 thinkpad
There's no hardware switch to activate and deactivate the wireless networking, but pressing Fn and F5 brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both. It seems like IBM isn't satisfied with standard toggle buttons like other notebook manufacturers - even pressing the Fn and F7 buttons to switch between internal and external screens, brings up a menu with multiple display settings and resolutions.
Hope this helps,
David
Mar 10, 2009 | IBM ThinkPad T42 Notebook
I have a presario f500 my wi fi dont work is there a recall back on my model
you need to turn on the wireless card by pressing fn+F2 at the same time and then setup a wireless network from control panel network connections.
Aug 25, 2008 | Computers & Internet
ViewSonic ViewMate Keyboard Logo
18 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
