Krups 572 Power Xtreme VI Work Top Blender
Problem for Krups 572 Power Xtreme VI Work Top Blender
By ttcindy on May 13, 2008
After 10 years of very light use, my blender refuses to work. Pres any button and the result is the same: nothing. Please help.
Thanks,
Cindy
Best Solution
posted on Feb 03, 2009
Very Helpful)
TheLarryBrow
Rank: Apprentice
Rating: 92%, 3 votes
Repairing the blender:
My guess: You worked the motor too hard on your last blending session and it overheated. That will cause a thermal fuse inside to cut off. The blender won't work again until you replace the fuse but otherwise it should be fine. The fuse looks like a white diode and it will be attached tightly to the motor with a nylon strap (so that it can pick up the heat of the motor). The leads to the fuse are shielded with heat resistant nylon wrap. You will need to remove the rubber drive gear in order to remove the plastic house so you can work, although if you are really handy you might be able to at least test the unit by only removing the plastic bottom on the base unit.
To remove the plastic housing, remove the little rubber feet and then remove all of the screws on the bottom of the unit. You may need to buy a bit set for tamper resistant screws (I ***hate*** those), I don't remember. When the bottom is removed, you will see that the there is a screw head on the bottom of the central motor shaft. You can use a screw driver here to hold the motor from turning, then you can carefully use a pliers to unscrew the rubber drive gear on the top of the base unit (try not to damage the rubber). With the gear removed you can get access to the wires.
To test the fuse unit, just check its continuity. Short=good, open=bad. To further test, short out the fuse with a jumper cable and your blender should work.
EPO (Electronics Parts Outlet) in Houston, TX, has the replacement fuse unit. I don't know that they like mail order.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 20, 2008
Not Rated)
markoch
Rank: Apprentice
Rating: 0%, 0 votes
Mine quit also.
I put in a toggle switch that bypasses the circuit board and now it works fine.  Only one speed now, but what the heck.
It only took a few minutes.
Mark
Was this helpful?
Yes
No
Popular Solutions for Krups 572 Power Xtreme VI Work
Questions and Unsolved Problems for Krups 572 Power Xtreme VI Work
Do you recommend Krups 572 Power Xtreme VI Work Top Blender?
Answer
Answer
my 572 is leaking through the bottom of the jar and i am not sure if it is the gasket or the blade... (More)
Answer
why does the food leak out of the bottom of the glass where the gear is (the gasket is in place)
Answer
the blender works.... just when you remove it from the base there is like half the food that leaked... (More)
Answer
If I plug in and turn on blender, it works fine. However, when I put the glass with blade connected... (More)
Answer
I've seen how to remove the rubber/plastic gear drive at the top, but how do I find a replacement?... (More)
Describe your Blenders problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Blender Experts
Top Small Appliance Repairmen
in , GA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
