Question about Hotpoint HSS25GFP Side by Side Refrigerator
My refrigerator will run great for 48 hours and then it is like a oven when you open the door to the refrigerator or freezer, it is like a blast of hot air. I can upplug it and then plug back up and it will run fine for a while and then will stop cooling again.
  • Hotpoint Master
  • 43,501 Answers
My guess would be that the defrost is sticking on...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
My son left the freezer door openk on but it is struggling to freeze. After 48 hours it has not reached the desired temperature of -18 degrees C. What should I do?
Unplug and open the doors to allow the freezer to defrost the excess moisture pulled in by having the door open so long. Once the ice that you cannot see behind the freezer wall melts plug power cord back in and it should work fine. Do you have a model number? I'm here should you have question, Thanks, Sea Breeze
Oct 11, 2015 | Refrigerators
Freezer door accidentally left open. back of freezer iced up. can using a hair dryer carefully thaw the defrost and thermostat controls and get normal function?
it could be used provided that the drier was not on high and too close to the units
Sometimes it is jut better to leave the door open with a fan running full blast into the freezer as the continuous supply of air will defrost it quickly
place old towels /rags at the door opening to soak up the water
Aug 28, 2015 | Refrigerators
My GE Refrigerator doesn't work properly.
The two main causes for your problem is the control set wrong and the second one isthe defrost element has burned out... Sometime the defrost clock will go out as well.... always try to set your controls to midrange and if the bottom of the freezer compartment is cold and frosty but the refrigerator is cold ... Remove all the food and store in a backup refrigerator you can rent from an appliance rental center... Unplug your refrigerator and let it defrost for 48 hours.... In the mean time open up the doors and clean it from top to bottom. place a fresh opened box of arm and hammer baking soda in the frige side and one in the freezer side. Plug back in after completely deftosted and place a small plastic cup half filled with water on each shelf of the freezer. Close the doors and wait 8 hours... Open the freezer and check the plastic cups.... if they are all frozen great..now wait for 3 days do the test again if the bottom cup is frozen and the top shelf is not ... its time for a new defrost element or a defrost timer.
25 years service
stocktongoodrepair@gmail.com
Sep 21, 2014 | GE Refrigerators
How do i unthaw the delivery chute without breaking it?
Take everything out of your freezer and store it somewhere else (like another freezer, or cool bags with ice packs.
Leave the door open with a towel hanging over the top to prevent it from shutting. Disconnect the freezer from the mains and leave it for 48 hours to completely defrost.
The floor will get wet, so prepare for some mopping!!
Jul 24, 2014 | LG 21.0 Cu. Ft. Counter-Depth Side-by-Side...
Freezer not cold but refrigerator still cool
HI JULIE.TRY DEFROSTING ALL FIRST 24/48 HOURS.(USE ALTERNATIVES FOR FASTER DEFROSTING.ie;hair dryer;steamer;boiling water bowls etc.)if ok after that great.if same again then 1-defrost timer 2-defrost heater 3- t/stat.good luckALI
Jun 30, 2012 | Maytag MBB1954G Bottom Freezer...
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Blocked drain pipe from freezer
you need to defrost the unit for 48 hours with both doors open, then try using some curtain wire up the drain and see what comes out.
cheers
Mar 24, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
"Help" Missing refrigerator door sensor & compressor is continuously running..
could be, since if the computer senses that the doors are open, then he would turn the compressor continuously in order to compensate for the losses of an open door refrigerator.
but with this kind of alarm, im sure it should have turn the refrigerator off if it has been sensing that the doors are open for the past 48 hours.
another thing to consider is that since it is second hand, it could have been repaired and things done to it for the compressor to run continuous.
tnx 4 using fixya,
drcool
Aug 12, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
