Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
I have a kemore refrigetator 69272 5LH0, the bottom freezer works, but the top refrigetaror stopped cooling, not even air will come out the inside grill, how can i fix this problem before my food goes bad ?
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
My bottom freezer cools ok but my top freezer is warm what could cause this problem ,,kemore ,,model 59662913200
My guess would be that the defrost is sticking on...
heatman101
Sep 06, 2010 | Kenmore Refrigerators
The bottom part of my refrigerator is not cooling properly.
Something inside the freezer compartment may be causing this. Unplug the refrigerator and remove the rear panel inside the freezer to examine the evaporator coil. It may not be defrosting properly and blocking the air flow to the lower section. Let me know what you find. If snow and ice is present defrost with a hair dryer and we need to check the defrost heater a d defrost components. Sea Breeze
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigetator side is not cooling -JSD2789GES
No you may not fix it but you will know how to repair it and you can order the parts yourself. Find out if you have the defrost timer or the adaptive defrost inside the control panel inside the fresh food compartment. If timer turn clockwise until compressor stops running and the freezer should begin defrost. If the freezer begins defrost the defrost should end in about 25 minutes and the compressor should begin running again. If it does not the the timer is defective. If you would like the manual email me at appliancepartsse@yahoo.com
Jun 21, 2009 | Jenn-Air JSD2789GES Side by Side...
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Aug 18, 2008 | Refrigerators
Freezer up top cools but not at the bottom .
I think you must call a technician to check the air damper control and have an adjustment for the air passage to avoid clogging of ice to the air vent located at inside the freezer section cover.And to check if theres air leakage on the gasket of the fridge.
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
