Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Model #KUDPO1ILBL3 has no indication lts. It does have 110V at Pwr. supply box on under side of dishwasher. Door seems to close tight but still no lts. or solenoid opening.
SOURCE: dishwasher door latch
Has anyone had any luck figuring this one out?
Posted on Aug 15, 2008
  • 55 Answers
SOURCE: Dishwasher
  1. could be a latch adjustment-- push gently on the doo when you hear the chatter. could also be something lodged in or near the level switch-located around the waterlevel--check manual
Posted on Aug 28, 2008
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
tborn6
  • 700 Answers
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
Hi. I have a Bosch dishwasher and model is SMS60M18AU04 and it has a E16 error code. Do you can help me about it? Thanks.
The E16 error indicates a problem with the incoming water to the dishwasher. There are a few possible causes. If no water enters the dishwasher, make sure that the water supply shut-off is open. Next make sure that the supply hose is undamaged and isn't kinked. Replace the hose if it is damaged. Check that the water level float isn't blocked. If debris or a loose item got under the float, it will cause the dishwasher to keep the washer inlet valve closed to avoid flooding problems. Test if the dishwasher runs properly after checking the hose, opening the shut-off and cleaning under the float.
Check that the anti-flood switch hasn't detected a leak under the washer. This will also prevent the washer inlet valve from opening. Make sure that there are no blockages in the spray arms or between the pump and the spray arms.
If the above items are not causing the problem, then the inlet valve may have failed in the closed position. Replace the valve. The other possibility is that the door closed switch fails to detect that the dishwasher is closed. Checking this switch requires opening the inside of the door panel. If it is faulty, you'll need to replace it.
Some of the parts for the SMS60M18AU04 are available here: http://spares.bigwarehouse.com.au/index.php?cPath=80712_80715_103636 .
I hope this helps.
Jul 06, 2016 | Bosch Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
MOISTURE AND HEAT ESCAPE FROM DOOR SIDES CAUSING PROBLEMS WITH ADJOINING CABINET DOORS. WHAT IS CAUSING THE CONDENSATION / MOISYURE LEAK?
Unfortunately, dishwasher generate a lot of heat and water vapor. Some manufactures are now including a pressure sensitive mylar / aluminum strip to be attached above the door under the counter to prevent water vapor and or heat damage to wood or composition wood counter tops. However if water vapor is seeping out from the side of the door and causing damage to the adjacent cabinets woodwaork, the dishwasher door gasket may be faulty. Since this might be the problem, it would appear that your dishwasher is used a lot or getting old. New gasket is about $20. If the door closes and there appears to be a lot of play in the closed door,the latch may be in need of adjusting if possible. That is, even thought closed and operational, the seal is not tight and the dishwasher is running without having a tight seal on the sides. If you have a stone counter top, any water vapor / heat escaping from the top would not be apparent since stone is not damaged by the heat or water vapor, but the adjacent wood cabinets are.
Jan 15, 2010 | Frigidaire Dishwashers
2002 jeep liberty interior fuse diagram
1-20amp-pwr outlet frt. 2-10amp-rear fog lights(export only)
3-15 amp-horn 4-10amp-hedlt low beam rt
5-10amp-hedlt low beam lft 6-20amp-bodycontrolmodule/pwr dr locks 7-spare 8-spare 9-10amp- rt pk lt /rt tail lt/trailer tow lt/cluster
10-spare 11-15 amp-flasher 12-15 amp-stop lts
13-10amp-bodycontrolmodule/cmtc/cluster 14-spare
15-10amp-pdc fuel pmp & auto shutdownrelays/skis
16-20amp-pwr outlet rear 17-15amp-rear wiper 18-20amp-radio choke relay 19-20amp-frt fog lts/trailer tow stop and turn lts
20-20amp-sunroof 21-spare 22-10amp-wiperswitch/frt and rear washer 23-10amp-lft park lt/lft tail lt 24-10amp-pdc blower motor relay 25-10amp-heatseatswitch/hvac controlhead/trailor tow battery charge 26-10amp-hedlt highbeam rt 27-10amp-hedlt highbeam lft
28-spare 29-15amp-heated seat module 30-10amp-heated mirrors/rearwindowdefrosterindicator 31-20amp-cigarlighter
32-10amp-radio/frtdoorlockswitches/bodycontrolmodule
33-10amp-skis/diagnostic connector 34-15amp-cluster/courtesy lts/radio/bodycontrolmodule/maplights/cmtc/underhood lt/vanity lts
35-spare 36-10amp-ignition run/start-orc/lft and rt siacm
37-10amp-ignition run only-orc 38-10amp-abs module/brake shift interlock solenoid 39-10amp-rear window defroster relay/flasher/backup lts
Jul 03, 2009 | 2002 Jeep Liberty
Wil not fill with water
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
  • The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched. The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
    If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
    It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch
    Sep 21, 2008 | Dishwashers
    Leaking problem from the door
    hi there,
    dishwasher leaking might be due to either of these causes, check these:
    Main tub seal
    Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
    of the dishwasher, the following instructions probably apply to you.
    But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
    entire pump and motor assembly.
    The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
    leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
    remove the:
    * Lower rack
    *Spray arm
    * Spray arm support
    * Wash/drain impellers
    Then try the seal out of its housing and replace it.
    Door gasket or seal
    Over time, door gaskets and seals harden and lose their ability to seal properly.
    You can't repair the seals. You need to replace them if they've begun to leak.
    Water-inlet valve
    The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
    rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
    or repair/replace these as necessary.
    The water-inlet valve could mechanically stick open. When that happens, the water continues
    to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
    dishwasher, and replace the valve.
    Hoses
    Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
    leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    May 03, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
    Kenmore 665-15962 Elite 8 yrs old
    Won't start nor drain. what could the problem be? please help.
    Apr 02, 2008 | Kenmore 15872 Dishwasher
    There is power to unit, but will not light up and operate
    if you can confirm power to junction box under machine(110v). hte ntheres a fuse located on the control board p/n675813, thats the likely source.the fuse will have no continuity if bad. new fuse problably comes shipped with new wires and instruction sheet on how to install
    Feb 27, 2008 | Whirlpool 24 in. DU930PWP Built-in...
    A new gasket will usually seem too tight, as long as it's the proper gasket and you are sure it is properly in place, this may help. Using a hair dryer, carefully warm the gasket up, don't get it too hot that it deforms. Then close the dishwasher door making sure it latches. Run it through a cycle and use the heated dry option. Leave it closed overnite. This should help, although it may seem a little tough to close for the next few times you run it. It will get better with use.
    Jan 24, 2008 | Dishwashers
    KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
    Top KitchenAid Dishwashers Experts
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
