Question about Home
Due to city water line repairs, the shower head needs to be taken apart and cleaned. I have remved the head, but can't figure out how to disassemble it.
  • 50 Answers
Most modern multi function shower heads cannot be disassembled. Spray water into the outlet part to remove larger bits, then leave in vinegar and water solution (50:50) overnight to remove calcium build up.
Posted on Sep 06, 2010
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
I need to put back flow restrictor in Grohe shower head due to drought, how do I do ?
are you sure that is where it needs to be . as I have never heard of them being attached to a shower head . usually they will be put on the main water inlet line to the home or business
Jun 21, 2015 | Grohe Home
How do I get the pulse function to work after cleaning the shower head (fixed)
I am not familiar with this faucet, but in the future, don't disassemble it. Just take the head off and soak in a mixture of warm water and vinegar for a couple of hours and take a toothbrush to it.
Jul 13, 2014 | Grohe Home
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
My mira sport shower is only 2 years old just over and is leaking from the shower head I have taken the head off, is it the washer or do I need a new shower head? Sorry I am unable to give you the brand....
firstly clean all the shower holes with a needle tip. you can also apply some descaler on the shower. Cut an old cycle tube piece round to the size of shower head. Make a hole in the centre of the cutted piece.Apply some grease on the patch & place it between the shower & head. Tight it up.If there is not enough space for rubber just apply grease on the head & tight it.
Aug 13, 2010 | Home
How do i disassemble this shower head to clean out the mineral deposit?
Most often the shower head will be threaded together. Use 2 strap wrenches to take it apart. The strap wrenches will not damage the finish. Do not force it if the fixture does not come apart easily. Soak the head in vinegar overnight to loosen the mineral deposits and make it easier to work with. Good Luck
Jul 12, 2010 | Grohe 27.069.EN0 Relexa Ultra Shower Head...
Shower fell apart or actually blew off under water pressure
Check water pressure valve if you are on city water it may be bad and allowing water to be more than it can take.
If this is the case you can make you up a gauge on a water hose connection to hook up to and outside faucet to get a pressure reading.
May 02, 2010 | Grohe 28.444.AV0 Movario 5 Spray Hand...
I need to disassemble cuisinart dgb600bc
Screws are Torqux Tamper-proof/Safety screws size T-10. It's a Torqux screw with a raised middle requiring a special Torqux wrench. After looking all over I found a T-Handle set at Sears for $35.
http://www.tamperproof.com/
Jan 02, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Jan 25, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Home Logo
103 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
