Question about Refrigerators
No cooling. fan was running not the compressor vacuum the coils i could get to then pluged back in ran for a while but then quit. now no fan or compressor.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
My compressor cooling fan quit- the compressor still runs. I unplugged the unit then plugged it back in. The cooling fan ran for about 15 seconds, then shut off again. Is the problem with the main control...
The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Jun 23, 2010 | KitchenAid Superba Architect KSCS25INSS...
My frigidaire side by side quit cooling about two months ago i un pluged it cleand everything and let it sit for about 3 days pluged it back in and it worked for almost 2 months now it is not cooling again...
there sunds to me like there is a problem with you defrost cycle.how ever how need to look for any ice build up in the bottom side of the freezer section.
while the unit is the cooling mode open the freezer door and listen for a fan running if you do not hear a fan running you may need to replace it the door switch should be held in while you are checking this.
then i would alos look at the overload relay and start switch on the compressor.
Jan 31, 2010 | Frigidaire FRS26R4A Side by Side...
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
Refrigerator freezer not cooling or freezing took off back cover. fan operates. compressor is hot, when pluged in humming noise then drops out.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Crosley CFFH10W Top Freezer Refrigerator
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Circulation fans quit running after we shut down the compressor, and won't come back on . even though the fan when pluged direct to out let works.
check the door switches and see if they are engaging when the doors are shut. they are mounted just above each door. If just one is not being pressed in it will keep all of the inside fans off. also there is afan delay mounted by the inside coil that will keep the fans off until the coill cools to a certain set point to prevent recirculating hot air. depending on conditions it may take the fans a good 15 minutes to come on ,or longer in a very hot start up.
Feb 22, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
