Question about Mantis 2-Cycle Tiller
STARTS OK WITH PUMPING THE FUEL BULB AND CHOKING AFTER SEVERAL PULLS AN DRUNS IN IDLE BUT WHEN I TRY TO GIVE IT GAS IT DIES.
  • 1,040 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Sep 09, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Did this, or would it have help you to solve the problem. Please rate my answer if so.
    Thanks!
    Jim
Starts dies
an alternator won't stall your car, the battery provides power to keep the spark going. It sounds like you could have some bad fuel, if you're able to run the throttle manually with your foot and keep it going that would indicate idle control. but if it stalls still when you are giving it gas. I would guess a fuel supply issue, either water in your gas, or fuel pump. Good Luck.
Dec 03, 2013 | Cars & Trucks
Huskvarana blower 130BT starts but will not stay running
Fueling issue, check primer bulb and fuel line for air leaks, and possible clean and service card.
Dec 27, 2012 | Husqvarna Garden
1998 chevy 1 ton 4x4 diesel starts then stalls after gas is given
sounds like you got somethin in your tank or lines. Do you only have one fuel filter? Did you change your air filter by a chance? Start ther then let us know
Apr 04, 2010 | 1998 GMC Sierra
91 s10 2.8 will not idle but will run when pumping the gas but if u give to much gas it dies ive replaced plugs wires fuel pump fuel filter air mixture censor
if fuel injected there is a solinoid that opens the air intake s o the truck will run when not pushing on the gas pedel , that is stuck shut.
Oct 24, 2009 | 1991 Chevrolet S-10
Engine starts but dies immediatly unless i keep pumping gas
Check the electrical for key on power to the fuel pump relay, it sounds like the pump will only run in the start position.
Jul 19, 2009 | 1988 Chevrolet C1500
Engine starts but will not idle, i give it gas but will not sustain in running afyer 2 seconds engine dies
check all spark plugs and wires also check mass air flow senser located on intake tube if all is still in good working condition check the throttle position sensor if that is good then it may be your fuel pump please update when possable.
Jul 08, 2009 | 2001 Ford Focus
Put in new carb kit, starts but dies after a few seconds
If you removed the fuel lines from the primer bulb you may have reversed the lines. On two stroke engines the primer pulls gas through the carb it does not push gas into the carb. On the back of the primer bulb there are two hose barbs, one says in (in very small letters) this side goes to the carburetor and the other goes to your gas tank (it is a return line) This line is about a third to a half way up the side of your gas tank, not at the bottom where the fuel line is.
Jul 04, 2009 | Craftsman Convertible 25cc. Gas Line...
Engine won't run unless primer bulb is being pumped
I have the same problem and may have a solution. I looked at the primer pump and it was cracked letting air into the system. When I pumped it my finger was over the crack and it worked fine. When I stopped the crack was able to **** air again. Take a look.
Jun 20, 2009 | Boating
Mantis 2-Cycle Tiller Logo
70 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
