Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
When tv is turned on you can only hear the audio and no picture. It shuts off after 10 seconds
When tv is turned on you can only hear the audio and no picture. It shut off after 10 seconds
Posted on Oct 26, 2010
  • pap167 Oct 27, 2010
    HELP Same Problem here... :-(
4 Suggested Answers
  • 1694 Answers
SOURCE: TV turns off after 10 seconds
Check signal board surface for evidence of CRT coolant
leak onto PC board = access thru front of set = remove
speaker grill cover & access panel = look with good light =
any wet spot ??.......................................T.
Please rate this solution.............................
Posted on Nov 13, 2007
SOURCE: No picture, hear sound, television will shut off after a few seconds.
Take out the bulb (back left hatch door) look to see if the element inside the bulb is broken or blackened - (replace bulb) if the bulb looks OK then it's the ballast that fires the bulb (service call).
Raf
Posted on Nov 30, 2007
SOURCE: HD65W20JX1 RCA SCENIUM THOMPSON MULTIMEDIA
yep i had same bought seconhand off ebay repaired in ten minutes its the transistor situated on power board directly at back of high tension coil cost approx £1.90 easy fix
Posted on Oct 22, 2008
It don't show on my television scene
Hook up to tv like normal....Hold down power button for 10-15 seconds or until you hear 2 beeps. If it shuts off, just turn it back on and that will reset your audio and video out from ps3.
Oct 19, 2010 | Sony PlayStation® 3 (80GB) Console
When tv is turned on you can only hear the audio and no picture. It shuts off after 10 seconds, IS SONY KDP-65WS550
First try replacing STK ICs (2) of them STK392-560s
Mats has them 1-800-628-1118 Also CK pico fuses they will look like resistors But are Fuses 6amps 7amps will be Yellow or Green.
Oct 05, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
We have a Samsung HLP5674WX/XAA which seems to have a mind of it's own. It will automatically shut off or when we turn it own, there will be no picture with sound or once it turns on, the TV will shut...
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
Mar 18, 2008 | Televison & Video
Picture and screen
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 02, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture
Hello pravinp,
Since this is a DLP set, The bulb becomes suspect. I would take the bulb out and measure the voltage in the socket from which the bulb was taken to determine if the socket is hot. If it is I would then take a resistance reading of the bulb, the resistance should be at 0 ohms. If your bulb is blown replace it with the exact type. The TV might be shutting down to prevent further damage from occurring
I hope this helps
Shuttle83
Dec 21, 2007 | Toshiba 62HM95 62" HDTV
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
