Question about Vacuums
OEL flashes red on wella xpert clippers - Vacuums
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
How do I fix dyson cordless vaccum flashing red light
Hi there, it's Jack at Dyson.
A flashing red light from a Dyson cordless vacuum signals a fault with the machine. We're happy to take you through some simple diagnostic checks over the phone when you have your machine easily to hand - just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
If a replacement part is needed we can also confirm if this is covered under your Dyson guarantee.
We'll look forward to speaking with you.
Feb 20, 2015 | Dyson Vacuums
What is orange/red flashing when charging
The color flashing tells you how close you are to a full charge. The orange/red flashing should change to yellow and finally green. Sorry I have an original model so your's might be slightly different. Does it never change from orange/red?
Jul 03, 2014 | iRobot Roomba 550 Vacuum
Sounds as if the trimmer is on but not with full power, is not able to cut hair?
Your clippers probably just need to be cleaned and oiled.
Unplug the clippers, then use a philips screwdriver to take off the clipper plate and reciprocating blade, and then thoroughly clean out all the hair residue from inside. Q-Tips seem to work fine for this job.
Here is one short Youtube video that demonsrates the basic process:
http://www.youtube.com/watch?v=43CpUK2AghA
I just use light mineral oil from the drug store to lubricate mine and it seems to work fine. Normally you are only supposed to use a few drops of oil when you put it back together, but you can really use as much as you like on the blade / plate area, just try not to get any down inside the body of the unit. Then just be sure let it run for 10 seconds or so and then wipe off the excess oil with a paper towel prior to using it next time.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 01, 2011 | Vacuums
The clippers are back together but are cutting the skin and still dont sound right did i put them together right.
Did you remove the comb and blade only? If so, the comb (the part that doesn't move and is closest to the skin) should extend beyond the reach of the blade (the part that does move left and right). Nicking is sometimes caused by excessive pressure against the skin. A properly adjusted blade will resemble someone with an underbite (extended lower jar) with the comb part extending beyond the blade.
Most clippers have a clatter adjustment screw. Turn this until the clipper clatters (buzzes really loud) and then adjust it back until the clatter stops (but not too far or you will lose power and the blade will stall or cut slowly). Be sure to oil the blades. Mineral oil (from a drugstore) will do if you can't get shaver oil.
Good luck from Detroit, MI
Apr 29, 2011 | Vacuums
There is a flashing red light on my rainbow e2 machine?
There is a flashing red light on my rainbow e2 and little smells bad
Dec 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
"New" Rainbow Eseries flashing red light
This is fine it is an indicator light that the computer is working.
Feb 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
115 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
