Question about Toshiba TLP S30 Multimedia Projector
Unsupported Signal After I connect my Dell Inspiron Laptop to the TLP-S30 projector, start the projector, and then turn on the computer, the message on the screen is: "Unsupport Signal." This process had been working well, but suddenly this problem prevents my use of the projector.
  • 563 Answers
Hi Circuitrider
Just change the resolution on your PC to match that of the Projector i.e. XGA Projector = 1024x768 resoltuion.
If the problem still persists , the Mainboard is at fault and will need either replacement or repair.
Posted on May 14, 2008
When I project, the display on the wall is green, can't figure out why. Is it the INPUT into the projector?
i have lcd projector but problem to connect dell vostro 1510 only not show laptop. only show lcd projector but without show laptop. i need both laptop show and lcd projector how explain me.thank
Apr 27, 2010 | Toshiba TLP S30 Multimedia Projector
Connecting projector to Dell Vostro 1500 but getting no signal message
Press <Fn><F8> to switch the video image between the display only, the
external device only, or the display and the external device simultaneously
Feb 17, 2010 | Toshiba TLP S30 Multimedia Projector
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
No signal projector (TLP-S71)message connect to laptop
make sure the cable is good. then make sure the resolution matches.
Jul 28, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP XD-2000
There are two things it could be...
First, how far are you trying to run the cable for? When you run longer distance a humbucker might be needed. Or it means that the internal distribution output has bad vertical and horizontal connections.
Jul 21, 2009 | Toshiba TLP S30 Multimedia Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
Connected to mac
reset the laptop with the video cable hooked up
Feb 20, 2009 | Toshiba TLP S30 Multimedia Projector
TDP-S20
Click the 2 box on the display settings and put a check mark ano the box that is say to extend the view on to this monitor. Hope this Helps.
Jun 17, 2008 | Toshiba TLP S30 Multimedia Projector
N o signal
Hi momawarbucks
Check if your secondary screen is attached by going to desktop and right click , then go to properties and advanced.
Also check if your refresh rate is on 60-70 Hz
And that the resolution your PC is on , is supported by your Projector - i.e. XGA Projector - 1024x768
Good luck and thanks for using Fixya !
May 17, 2008 | Toshiba TLP S30 Multimedia Projector
Hey Guys
Auset
You can go to www.projectorcentral.com and go to Projector brands.
Simply click on on your brand and model and download the Users Manual and burn to CD if you wish.
Mar 22, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
1,186 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
