Question about Mitsubishi WS-65905 65" Rear Projection Television
No picture on my set. (Mitsubishi ws-65905)
Well it all started off with a bunch of red lines thru out the screen (alot on dark picture) then the picture went out. i have had no other problems but this. really can't afford to purchase a new set right now so any help would be greatly appreciated. thanks!!!!!!!
I have the same problem. I had someone come out and take a look at it they told me it was a DM module or signal board. Unfortunately Mitsubishi does not make the part anymore!! I'm very upset. I'm not saying this is your problem, but look at it as a possibility...
Posted on Jul 19, 2008
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
Tv powers on, has sound but no picture. All three lights are working & will show the input display but distorted. I would like to do the repair myself but am not sure if this is a convergence issue or...
Even if a convergence problem exists you should still have a picture, a bad one but a picture----call the menu up with the Mitsubishi remote and select convergence and then advanced---a grid of lines will appear in green---got dramatic red and blue showing and you have a convergence issue.
Do that first----presuming no hookup is ok (try a dvd player) the set does have the OPTION menu(can tell you how to get there) that is based on a 4 digit number code--may have that for this model or not).
It will not correct any convergence problems but will do a hard reset of the set back to factory original.
Let me know what you find---it sounds like 2 problems exist.
Nov 07, 2012 | Mitsubishi WS-65905 65" Rear Projection...
My WS-65905 Mitsubishi when on an HD channel, makes the words fuzzy/blurry. What needs to be done. I talked with a TV repair guy and he says it might just be the lamp needing to be cleaned. Can I get a...
First: this model has three picture tubes--with lens--if they are dusty the picture will be duller and darker than it should be--if this was the case it would be the same HD or not.
Do not pay someone to do this--with set off and unplugged you will see the three lens--clean them with a lens cloth.
Second possible cause---CONVERGENCE.
This set has in the customer menu convergence adjustments done with the remote---they are separate in the HD from the non HD. They are done with the Mitsubishi remote and easy to do.
If convergence when you call up the menu for it the grid of yellow lines will have either red or blue out of position slightly.
A lot of these sets were never very well adjusted in the HD mode for this---check out the convergence in the NON HD FIRST!
Then go to a HD channel and call it up again---instructions on how to move, adjust etc will appear and you will know instantly if convergence is different on HD---easy to adjust.
If this works and you want to get the Convegence really good let me know--there is a way by model number to do the same adjustments but it saves them into the memory of the set.
Doing the adjustments in customer mode, if power is removed they may return to what they were before.
If all this information has helped you rate this solution as very helpful as I do this here for free.
SD TECH
Aug 16, 2010 | Mitsubishi WS-65905 65" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Where do I get parts?
Fixya is unable to suggest parts sources.
Nov 26, 2017 | Mitsubishi WS-65905 65" Rear Projection...
To much red in the picture
Yes, either some resistor has changed and it's pulling down the blue and green or depending on how much red it could be a short on the red line. Also you can open back of set and try this. Each CRT's have a Focus Block with Screen control. Maybe you can turn down red and align up with blue and green. The professional way of doing color is to get a good grey scale, meaning black and white picture. THis is turning down you color on set to zero and looking and adjusting to black and white as good as possible. You can try this but if there is a serious problem it may not help. The problem may have to be resolved first. Be very careful in touching anything while set is on, unfortunatly you have to have the set on to properly adjust. but you can use something plastic or rubber end screw drivers
Sep 06, 2007 | Mitsubishi WS-65411 65" Rear Projection...
Mitsubishi WS-65905 65" Rear Projection Television Logo
290 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
