Question about Whirlpool Microwave Ovens
I have a one touch microwave & have misplaced the manual. The code F2 keeps coming up on the display. What does this mean?
  • Whirlpool Master
  • 9,098 Answers
F2 on a Whirlpool microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Please reply back with your full model number from the tag in or on the unit so we can help you with an estimate or free DIY tips.
Posted on Sep 08, 2010
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
What doesl f2 mean on the display
The "F2" on a microwave can mean that the touch pad has a problem. Once I saw that message on a stove. The technician told me to press the "stop/cancel" button two times to reset the electronics. That fixed it. The electronics inside the microwave are usually timers and they adjust the strength of the microwaves for cooking. The best thing to do if the stop/cancel trick does not work, is to look at the owner's manual. If there is nothing there referring to that code, then copy the model number from the microwave (usually inside the door panel or sometimes at the back of the unit) and go to the manufacturer's website. Look for support, enter the required information and find out what the code really means.
Many times, it is better to let a professional take care of a repair on a microwave. If you leave something loose or not properly installed, you could endanger your health with microwaves hitting you improperly. Always be careful when working with this type of equipment.
Jul 16, 2011 | Microwave Ovens
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
Jan 25, 2011 | GE Microwave Ovens
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
The microwave is displaying "-F2-" on its screen and will not otherwise work. What do you think the problem is?
It is a bad keyboard error code. Try this, unplugg the unit, open the control panel and disconnect the ribbon cable from the control board, plugg back in, if f2 comes back on the board needs replacing, if it does not, then the problem is with the keypad.
F2 means you have a shorted membrane keypad, which would have to be replaced.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
good luck
dont forget to rate the service......
Aug 18, 2009 | Whirlpool MH8150XJ Microwave Oven
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Error code F2.Q1
Not sure what you mean by "Q1 Touch FMEA" above, but F2 error code indicates a bad keypad or sometimes a bad sensor.
Since it's brand new I would first consult the manual. If you don't have it still, you can download it from the owner center here: http://whirlpool.com/custserv/index.jsp
If you still have trouble, since it's new, it should obviously be under warranty, so I'd contact them (same page as shown above) to get it repaired under warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 01, 2008 | Whirlpool GH7208XR Convection / Microwave...
Microwave Ovens Logo
222 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
