Question about Kenmore Elite 45986 Front Load Washer
What does it mean when the cycle is interrupted & a H & F appear
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
A star appears in the satuts area what does that mean
The Star is one of the new features (in Lollipop) and is called "interruptions" mode , which can be activated in settings. If the interrupt mode is activated as "Priority" , the star icon in the status bar of your Android smartphone appears. "Priority" in the "Interruptions Mode" means that only calls and notifications appear , which you have previously considered as important.
For the classification, navigate from the home screen of your Android smartphone:
Menu --> Settings --> Sound & Notifications --> interruptions
Now you know what the the star stands for in and how you can set settings in interruption mode. To turn interrupt mode off quickly, press once on the volume button and then select from
- None
- Priority
- All
the entry "All". Finished!
The star icon is now hidden and the interrupt mode disabled in Android lollipop.
Oct 12, 2015 | Cell Phones
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
Sharp ar-164 - Displays "h4"
this error means:
heat roller abnormally low temperature.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 25, 2012 | Sharp AR-164 Copier
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Just hada brief power flash. Washing machinbe was on. Now just keeps beeping with E60 lfashing on the screen. Not continuing cycle. Can't open door. Can;t re set
The E60 is not listed but it means the cycle was interrupted due to a fault with the motor.
You don't provide many details about what is happening or when the code is displayed.
Try to run a drain and spin cycle and see if the motor will turn.
The E60 error most likely means there is a problem with the motor.
Mar 13, 2011 | Washing Machines
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Dishwasher is blinking PF what does that mean?
howdy, PF means power failure. There was evidently an interruption. If it has a clock this requires a reset, otherwise you should be able to clear it by reselecting your preferred cycles or timer.
Farmerbear At FixYa.com
Sep 12, 2010 | Microwave Ovens
How do i shut off the energy saver compliant on xerox c20
For majority of the models Xerox entry in service mode holding [0], include the device.
Entry in service mode
Xerox 5845, 5855
Or include the device with simultaneously pressed button [Interruption] and [2], or on included device to press and hold these buttons more than 2 sec. If device faulty - an entry is realized button [Interruption] and [5], with restriction function (consecutively appearing reports on fault are thrown double keystroke [Foots]).
Hereinafter, the device calls четырQхзначный code of the access: this or 8765 (by default), or the last four numerals counter mines in inverse order (if counter mines shows 01234567 - a code of the input 7654).
Xerox N17, 24/32/40, 3225/4025
There is 3 diagnostic modes:
1 - are checked breakers, sensors and are removed parameters фьюзера, input: (2+6), after "IOT?" press "7" 2 - haves something published the test-sheet "net" in simplex or duplex, input: (2+6), after "IOT?" press "4" 3 - are changed parameters and adjusting the printer (NVRAM), input: (2+6), after "IOT?" press (4+7), "7" immediately release, "4" keep before appearance "3" on дисплее, then release.
XD102...155, XE60...84, XC800...1255
stop auto stop auto
sometimes write as C Density select C Density select (that same)
WC PE 16(e)
we type on keyboard [menu] - [#] - [1934] - [menu], after entering inscription "TECH" will appear in service menu
Oct 12, 2009 | Xerox CopyCentre C20 Black and White...
Error Code H2
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Jul 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Kenmore Elite 45986 Front Load Washer Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
