Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Sound Card I was finally able to copy the DOS PCI32 data to a word document as I was unsure where you wanted me to paste it. Please advise.
  • EFICMgr May 13, 2008
    Where am I suppose to paste the PCI32 data.
  • Jason Disbrow May 11, 2010
    paste it on here.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
EFICMgr:
Your original solution was provided by jrdtechnet, and if you wish further contact directly with that expert, it is best to do so as a further post on your original issue. Alternatively, you should see that expert listed on your profile page. Clicking on their link will send you to ask this question directly of them.
I am not experienced with PCI32, but the solution I find most helpful in regard to drivers is as follows. (The system basically does the work for you, and you should not have to do anything but what you are instructed within the process.):
Since detecting the type of equipment you have, and its numerous technical specifications, can be quite difficult, it may be easiest to use a site that will scan your system and determine the updates needed. Three available sites: www.driveragent.com, www.drivers.com, and www.drivershq.com. You may find this more helpful than trying to search for one individual driver, as that can be very difficult. If none of these things helps, please post back as to the outcome of the above. Otherwise, thanks for rating FixYa!
Posted on May 17, 2008
When on Facebook and it says copy and paste,i hold my finger on it and it says copied to clipboard,how do I find clipboard on my Acer tablet?
A clipboard is a temporary storage area for data that the user wants to copy from one place to another. In a word processor application, for example, the user might want to cut text from one part of a document and paste it in another part of the document or somewhere else.
GuruAid.com
Jun 29, 2016 | Acer Tablets & eReaders
How do you copy and paste one excel spreadsheet to another making sure the headers are lined up correctly.
right-click the sheet you want to copy, select "copy to", then either select the position within the current document, select annother document (needs to be open in the same excel instance) or select "new document". check the box "copy" to copy, leave unchecked to move.
Jan 01, 2016 | Microsoft Excel Computers & Internet
How do you cut and paste from one document to another
The Microsoft Office allows you to copy text andgraphical items from Office documents or other programs and paste them intoanother Office document. For example, you can copy text from an e-mail message,data from a workbook or datasheet, and a graphic from a presentation and thenpaste them all into a document. The simplest way to copy data from one documentto another is as under. However, there are numerous options/ possibilities. Step-1 Select / Highlight the text you wish to copy toother document. Step-2 Click the copy button (Or press Ctrl +C) Step-3 Go to the document where you want to paste thecopied data and press paste button (or press Ctrl+V) Let me know if any further clarification/ assistance isrequired. Hope this helps! Good Luck! CreativeTECH
Jan 12, 2011 | Microsoft Office Professional 2007 Full...
How can I copy and paste a document/item by using the keyboard
You can copy and paste using keys.
CTRL (+) C for copy
CTRL(+) V for pasting.
Nov 19, 2009 | Computers & Internet
I have a lenovo laptop and Microsoft office. How do I do a screen shot on this thing? The office won't let me ''paste' it for some reason.
Sometimes when the right click options do not work, you can revert to the old DOS command short cuts. I am unsure of the Fn + "F" key stroke to take a screen shot but the keyboard short cuts for copy, cut and paste are: copy is Ctrl + C, Cut is Ctrl + X, Paste is Ctrl + V
Oct 01, 2009 | Lenovo ThinkPad SL500 Notebook
How do I transfer pictures, music etc from the old computer to the new one
Several ways. Best is to get an external hard drive - they are cheap and they offer backup.
Another way is to hook up both computers on a network. can be done without a router or an ethernet hub - switch via a "cross" cable (as opposed to "patch" cable. Please be advised that the second option is by far cheaper but it could be a pain to set up properly.
Aug 31, 2009 | Computers & Internet
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
Mar 24, 2009 | Microsoft Excel for PC
How do I download infomation from my memory stick to the computer? Step by step
1) insert it into a card reader, then connect the card reader to usb drive.
2) Then go to my computer there u will see a removable drives click on it then select the files u want to copy then right click on it select copy.
3) Double click My Computer and double click C:\ drive, (make a new folder if u want to) then copy all the pics on it by right click on it and select paste.
Aug 01, 2008 | Computers & Internet
Sound Card
Try this. Put the PCI32 folder on your C: drive. Now use your mouse and click the start button, then click RUN. type CMD. A DOS window will pop-up.
In the DOS window type 'CD \' without the ' ' hit enter on your keyboard that should bring you to the c:\ . Next type 'cd pci32' enter to enter the pci32 folder Finally type 'pci32.exe' enter to run the program. It shouldn't close now.
May 13, 2008 | Microsoft Windows XP Professional With...
Sound card driver
I did a search of your FCC ID # and nothing was returned. It could not identify your product. Please be more specific. Was there no model #? Also, the main chip (usually the biggest) should have a model number. Try finding that.
By the way, to search FCC ID #'s, go here: https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
May 12, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
