Question about RCA Audio Players & Recorders
Tv won't turn on, and there's a ticking noise inside
  • 666 Answers
This is generally a fuse issue and will need a technician to assist with the repair but the part itself is rather cheap
hope this helps
Robb
Posted on Sep 06, 2010
Won't stop ticking!!!! Why??
The noise could be from the expansion and contraction of the metal from heating up and cooling down. You could try loosen the mounting screws of the unit slightly to see if that helps.
Dec 14, 2012 | Williams (5009622) Ceramic Gas Wall...
Ticking behind glovebox
Does it sound like the noise the turn signal makes? Does the noise change if you change the speed of the blower motor? Do all the function of the heater work (defrost, vent, floor, recirculate, fresh air, hot, cold)?
Nov 29, 2012 | 2003 Pontiac Sunfire
There is no picture and there is a tick tick ticking noise coming from inside the TV
The ticdk tick sound is probably the switched mode power supply making noise due to the fact that there is a shorted component inside(may be the horiz. output transistor). You may need to have service personell look at unit and get an estimate...this is older set n may not be worth repair
Jan 14, 2011 | Panasonic PT-51HX40 51" Rear Projection...
I have a ticking noise when i try to turn on the tv..
Try putting on the back piece. Some of these TVs have a circuit protection system that will not deactivate with the back open. (It is like an old circuit breaker with the fuse out.)
I hope this helps.
Jun 03, 2010 | Philips 50PL9126D/37B 50" DLP TV
Ticking TV
This noise come from a component that needs soldering, probably comes from one of the terminal were by any reason is not doing good contact. Or is the flyback, a component that uses high voltages to accelerate the rays inside the tube.Unfortunately, is not a big deal for a regular technician, but is a big trouble if you try tio open the TV. Is very risky because the mentioned component, along with others usually they work at ranges ol voltages of 50,000 or more volts. Although the current is not much, the shock is very unconfortable. Don't try, take it to a tech.
Nov 23, 2008 | Philips Magnavox TS3260C 32" TV
Samsung 21inch tv turned of while watching tried fuse still not working making a low ticking noise with the back removed?
is the noise coming from Flyback (a big greyish color unit inside the board, having a connector from picture tube).
if yes, then it could be caused by this..
regards,
Aug 07, 2008 | Televison & Video
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
Ticking noise
lost contact use soldiring iron
Sep 19, 2007 | Sanyo AVM-3659S 36" TV
64 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
