Question about Whirlpool GEW9250 Electric Dryer
Theres a buzzing sound when dryer turned to on and a smell of sometihing burning
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
Kenmore dryer model 86880100: Start button would just buzz when pressed, sometimes actually start the machine, then the machine would run for a few minutes and turn itself off with a burning smell. Now...
Sounds like a over heated motor which starts when the motor is cool but not after it runs and stop. Burning smell comes from the heated windings on the motor coils.
Make sure that the pully is not binding...which i doubt.
Oct 15, 2013 | Dryers
Kenmore Dryer 76812. The motor sounds like it wants to turn over but it smells like electrical burn and will not start. We cleaned all the lint from the back and around the motor. Any ideas on what we...
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...it will also get very hot and give you the burning electrical smell...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 11, 2010 | Dryers
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
Kenmore gas dryer made a loud buzzing sound and didn't start. I smelled burnt rubber smell. Dryer is totally unresponsive now. Breaker is ok, power is on.
Sounds like the belt has burned and broken. There is a switch on the tensioner that will not let the motor run if the belt breaks.
Dec 28, 2009 | Kenmore Dryers
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
KENMORE DRYER WILL NOT START
It sounds like the motor has burned up or is burning up is why you are getting that smell. There could at the same time be a wire that has come loose or burned off that is causing it not to come on.
Jan 26, 2009 | Kenmore 73952 Gas Dryer
Dryer not working all the time
99% of the time , a buzzing motor means the motor is almost burned up. Especially when you can smell it. A burnt motor calls for more current due to the laws of electricity and this overheats the motor windings and this is what you smell. If you are lucky, one other thing can cause a motor to buzz. Something is binding somewhere and the motor is not strong enough to turn the shaft. You would smell this also, but if you can find what is binding it and remove it, then you should be ok if you have not used it too much with it smelling. Look for a sock or wash rag tangled inside the dryer between the drum and the inner walls. This extra "drag" would cause the symptoms you are seeing, but something tells me that you have a burned up motor.
Mar 03, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
