Question about Peg Perego John Deere Gator HPX Ride on Toy
I need the white plastic connector that goes from the front of the vehicle to the battery.to connect the battery to the vehicle so it can be rode.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Do you still need this?
Posted on Jun 13, 2012
How to remove battery from an old firex fx1218 smoke detector
I agree that removing the battery can be a pain.
As you look up at the FX1218, turn the smoke detector a few degrees counterclockwise.
The detector should fall from the ceiling and hang by a few wires.
Those wires are connected to a plastic connector. It's the plastic connector that has to be squeezed using pliers. I prefer slip-joint pliers (see picture).
remove-battery-from-old-firex-fx1218-pakrl1cso4l3msuzip5hmw52-1-0.png On the plastic connector you will see two plastic "arms". Squeeze the arms and the plastic connector and cover plate to which it is attached will come out of the detector exposing the battery. Be prepared for the detector to screech.
Replace the battery.
Reattach the connector/plate. It is keyed so it only goes in one way. Be careful no to bend the interior male pins into the female plastic connector.
Apr 24, 2012 | Home Security
Connecting battaries for a Rascal Autogo
When you put the second battery in the case paying attention to polarity position, the longer wire will go to the top connector. If you have a voltmeter you can identify which wire has 12 volts on it. It should be the brown wire but verify anyway. This wire has to be connected to the NEGATIVE terminal of the second battery in order to get 24 volts to the scooter. The remaining wire connects to the positive terminal of the battery.
May 04, 2017 | Cars & Trucks
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
NEED TO INSTALL SARTER ON 1997 EXPLORER ALL WHEEL DRIVE
  1. Disconnect the negative battery cable.
  2. Raise the front of the vehicle and install jackstands beneath the frame. Firmly apply the parking brake and place blocks in back of the rear wheels.
  1. Tag and disconnect the wiring at the starter.
WARNING When detaching the hardshell connector at the S-terminal, grasp the plastic shell to pull it off. Do not pull on the wire itself. Ensure to pull the connector straight off to prevent damage to the connector and S-terminal. If any part of the connector is damaged, replace the damaged component.
  1. Remove the starter mounting bolts and remove the starter.
To install:
  1. Position the starter motor against the engine and install the mounting bolts. Tighten the mounting bolts to 15-19 ft. lbs. (21-27 Nm).
  2. Install the starter solenoid connector by pushing it straight on. Ensure that the connector locks in position with a notable click.
Install the starter cable nut to the starter solenoid B-terminal. Tighten the nut to 80-123 inch lbs. (9-14 Nm).
  1. Connect any remaining wiring to the starter motor.
  2. Lower the front of the vehicle and remove the wheel blocks.
  3. Connect the negative battery cable.
RELAY REPLACEMENT
See Figures 7 through 13
  1. Disconnect the negative battery cable from the battery.
  2. If necessary, remove the power distribution box cover.
  1. Disconnect the positive battery cable from the battery terminal.
  2. Remove the nut securing the positive battery cable to the relay.
0900c1528018eb9b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 10: Remove the cable securing nuts ...
  1. Remove the positive cable and any other wiring under that cable.
Fig. Fig. 11: ... then remove all of the cables from the relay
  1. Label and remove the push-on wires from the front of the relay.
  2. Remove the nut and disconnect the cable from the starter side of the relay.
Fig. Fig. 12: Remove the relay-to-fender apron attaching screws ...
Fig. Fig. 13: ... then remove the relay from the fender
  1. Remove the relay mounting bolts and remove the relay.
To install:
  1. Install the relay and mounting bolts. Tighten the mounting bolts until snug.
  2. Attach all wiring to the relay.
  3. If equipped, install the power distribution box cover.
  4. Connect the positive (+) cable to the battery.
  5. Connect the negative (-) cable to the battery.
Nov 11, 2009 | 1997 Ford Explorer AWD
I have a Hopkins Brake Control the pigtail colors are Red, White, Blue, Black. My 2008 Chevy 1500 pigtail colors are Red with a black strip, Light Blue with white strip, Dark Blue, Orange, White. How do i...
1. connect the red wire to the stop lamp switch lead on the brake control. Connect the other end of red wire to the stop lamp switch in the vehicle using the splice connector
2. connect the blue wire to the trailer brake lead on the brake control. Route the other end of the blue wire to the trailer connector at the back of the vehicle.
3. connect the white wire to the ground lead on the brake control. Route the other end of the white
wire to the vehicle’s battery. Use the ring connector to connect the white wire to the battery’s negative terminal.
4. connect the black wire to the power lead on the brake control. Route the other end of the black wire to the vehicle’s battery. Use the fuse assembly to connect the black wire to the battery’s positive terminal.
Oct 22, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Where is the fuel filter
On buick LeSabre the fuel filter will be under the car passenger side just in front of the rear tire . Follow the fuel line and you will find it there.
Oct 05, 2009 | 2000 Buick LeSabre
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
White oval spot in center of screen on garmin 2720 gps
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
If the touch screen is still working the moisture probably isn't between the layers. My guess is moisture got through one of the gaskets and made it's way in between the touch screen assembly and the TFT display.
If you want to clean it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the ones by the IR receiver.
Now that the touch screen is in your hand you can carefully clean the moisture from between the two assemblies. The gaskets are tricky to install again but it can be done, maybe you'll see where they were leaking.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Vanett charging problem
red & white feed to alternator,fed from top terminal of capless bulb in charging light, had a break in it. This is in the plastic tube that goes across the front of the engine in a r/h/d/ vehicle.
Sep 09, 2008 | Nissan Titan Cars & Trucks
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
