Question about Nikon Coolpix L22BLUE Digital Camera
The CD that came with my Coolpix L22 camera will not run on Windows XP, it works Ok with Vista but I need to install it on an XP machine.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Posted on Sep 06, 2010
How to reset nikon coolpix L22???
Open the "Menu". Scroll to the "Setup Menu" and then scroll to "Reset All". Press OK.
Jun 24, 2013 | Nikon Coolpix L22 Digital Camera
I've recently bought a Nikon Coolpix L22 camera, windows XP has no problem with it, but windows 7 cannot install the driver, it says "MTP USB DEVICE Failed", have tried so many things to fix...
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 29, 2010 | Nikon COOLPIX L2 Digital Camera
I am trying to download from the Nikon Coolpix L4 camera to my PC which is running on Windows Vista. I have downloaded the PictureProject software but the PC is not seeing the camera.
Did the camera come with a CD or DVD which had software on it? DId it also have drivers, such that when you plug the camera into a USB or other type of port, the PC will recognize the camera?
Frequently, the problem is that the camera is not "seen" by the computer, due to the drivers having not been installed.
Without those drivers. - software which enables the communication between the two devices - you won't be able to transfer the photos from the camera to the PC. And often, the drivers are specific to the version of Windows you are using.
So, if you use Windows Vista Home Premium, but have installed drivers for Windows XP Pro, there may be a miscommunication from that simple error.
Go back and read the installation guide, and make sure that you have not skipped a step, inadvertantly.
-a.
Nov 23, 2009 | Nikon COOLPIX L4 Digital Camera
Is Nikon Coolpix S210 software compatible with Vista???
my sis had the same problem she had to download some kind of software from the nikon website and it worked jus fine.
Aug 02, 2009 | Nikon Coolpix L11 Digital Camera
LifeCam 1.1 Microsoft XP
You can use your CD to insall the drivers for Vista also. Below is the procedure.
Select the Setup file and right click on it - - - - - >Select Properties- - - - - -> There you will find a menu for Compatability. Select it - - - - - - -> Select the Box to run in COMPATIBILITY MODE OF Windows XP (Service Pack 2) - - - - - ->In Privilege Level, select the box for RUN THIS PROGRAMME AS AN ADMINISTRATOR.- - - - - -> Apply - - - - - - -> OK.
Now run the Setup file and you will be able to install the driver for Vista and it will work for sure.
Apr 24, 2009 | Microsoft LifeCam VX-3000 Web Camera
Non-compatable software
Right Click Driver Installation, (open cd rom, not auto play) and click properties. on the tab click run in compatibility for and select xp. it should work. This works for multiple products.
Jan 07, 2009 | Nikon Coolpix 2000 Digital Camera
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix L22BLUE Digital Camera Logo
79 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
