Question about Rowenta Professional DX8900 Iron
Rowenta Advancer, model #DZ9080, is not heating and yellow and red lights on control wheel are flashing. Thank you.
  • carollandess Sep 06, 2010
    I deduct from your reply that there is a problem with the thermostat, since the iron does warm up to the touch but doesn't get hot. If the problem is the thermostat, is there a way for me to adjust it or will I need to get it serviced? I removed the base and all wires appear connected.
    Yes, thank you.
  • 2,382 Answers
Hi, you need to check that power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If power is getting to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
Posted on Sep 06, 2010
  • Tunde Autos
    Tunde Autos Sep 06, 2010
    Hi, if you are lucky it can be serviced but in most cases, thermostats are replaced...
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Heat goes off and red light blinks
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
Apr 24, 2014 | Rowenta Irons
My Rowenta DZ9080 has a flashing yellow light but no heat, can you help!
when I contacted rowneta about this they ask us to contact the repaire shop IN small appliance in NY I did mail them unit after stating the problem they have send me mail that They are unable to repaire the unit because of unavailability of parts and now they want additional amount to send me back the unit. Its just redicules to spedn 35% of cost to received unrepaire they could have told me before hand by model number and type of problem that they are unable to repaire This is really cheating on part of rowenta and repaire shops SO be carefull before you send it for repaire
Aug 20, 2011 | Rowenta DZ9080 Iron with Auto Shut-off
Lights come on but it don't heat up..
Sounds like a defective thermofuse. Rowenta doesn't encourage anyone to repair their product except their authorized service centers. Parts are not made available. Go to rowenta.com to find the nearest service center and call them.
Nov 07, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Only the green light lights up, dz9080 rowenta advancer iron
A small amount of White vinegar or some diluted dishwasher scale cleaner (calgon) added to the steam water then run it on steam setting ironing some waste fabric untill spotless.
Aug 01, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
My DZ9080 does not heat up. The lights come on.
If it does not heat up but lights is on, the reason being is the connection to the heaters is open or disconnected. It might be due to rust(water seepage) or overheat issues. Why the light is still on, its because the tap the supply to the led before the connections to the heaters. Try dismantling it to check the connection but most irons now is difficult to dismanlte without breaking something
Jun 10, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta DZ9080 iron yellow light flashes but iron doesn't get hot
it is possible that there is a loss in contact in the iron you will need a local repairs man to do that for you
Apr 27, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta Professional DX8900 Iron Logo
624 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
