Question about Radio Shack Pro-95 Handheld Scanner
Not scanning My Pro-95 will not scan at all. It seems the only way i can get it to work is to manually change the channels, upwards of 25 minutes. Then sometimes when it starts to scan, it will stop again. Any sugestions? Thanks , Jeff stormfan99@aim.com
  • ROBERT GONZALEZ Jun 30, 2008
    Same exact problem with mine.
    Bobby
    Bobby2you@aol.com
  • brian c
    brian c May 11, 2010
    Just to verify, you are turning the squelch up, right?
  • 90 Answers
Assuming that the squelch operates, the problem lies in a circuit that interfaces the squelch & scanning circuits. Probably not worth the cost of repair.
Posted on Sep 26, 2008
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
Scanning problem
i HAD THE SAME PROBLEM AND HAD TO GO TO ONE CHANNEL AT ATIME IN MANUAL AND HIT THE PROGRAM BUTTON TO RESET IT TO MEMEORY. YOU CAN TELL IF IT IS THE PROBLEM IF YOUR SCREEN READS "ALL CHANNELS LOCKED-OUT"
Jun 08, 2007 | Radio Shack Pro-95 Handheld Scanner
Pro-95 will not scan, when first turned on, unit goes to manual mode with last selected channel. Upon selecting SCAN, unit will switch to SCAN mode, but will not move off the bank of last selected...
If you did the hold down '2' '9' reset, there isn't much more you can do. I have tried pulling out the battery pack and putting in a jumper wire between both battery contacts inside the radio (with no battery) and turn it on and let it sit for 1/2 hour. That's about the last thing to try. Only other goofy thing could be you got 'sticky pop' on the 'manual' button, so the radio thinks you pushed the manual button as soon as you turn it on. Make sure that the rubber isn't stuck around the manual button. You could try a QTip with 70% alcohol around the edge of the MANUAL button, but you also might wipe off some lettering at the same time, so use caution. Good luck and let me know how it goes.
Apr 26, 2017 | Radio Shack Pro-95 Handheld Scanner
Will not scan. Screen shows banks and scan up message.
Try this,press manual,turn squelch to silent,press scan. hope this helps..
Mar 20, 2010 | Radio Shack Pro-95 Handheld Scanner
All channels locked on my radio shack pro-95 scanner
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct?
If you haven't programmed any frequencies the channels will stay locked out. Get your local frequencies by doing a search for police scanner frequencies. Once you have gotten the information for your area press the "PGM" button on the lower right hand side of the key pad. Input your 1st frequency ###.#### then press "ENTER". Press "PGM"key again and enter your 2nd frequency then "ENTER" again. Repeat as often as you wish to enter more frequencies.
Make sure you are entering your frequencies in empty channels unless you want to over write one that you don't want to use any longer. Press "PGM" until you get to an empty channel.
When you are done, (you can stop any time) press the "SCAN" button in the upper left hand position and you are in business. You are supposed to be able to choose which memory position you wish to use but I haven't tried to figure that one out.
If you need the manual for the radio go to radioshack site and do a search for PRO95 and it will come up in PDF format.
Hope this helps. I have owned the pro 95 for maybe 6 or 7 years and after doing a little programming yesterday the thing is much more to my liking. It scanns quicker and scans the channels I wish to listen to.
Jun 08, 2009 | Radio Shack Pro-95 Handheld Scanner
Pro 95 dual trunk tracking scanner just stays on channel 3 does not scan up to the other 10 channels
the manual at "http://support.radioshack.com/manuals/ome20-525.pdf" (if you don't have it)
says that you may be in manual mode OR that the channel at 3 might be a "trunk guide", that means that the channel is used to send out digital permissions to the system for each radio in the unit(s) to use a certain freq. when they transmit. good luck!
Mar 04, 2009 | Radio Shack Pro-95 Handheld Scanner
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
98 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
