Question about HP LaserJet 2840 All-In-One Printer
HP2840 not printing first 4 or 5 letters down left hand side. Problem exists when printing docs/Wordpad/Screen etc. Checked obvious things like margin settings but strange as only just begun to happen. Anything obvious I'm missing? Thank you
    Sniper:
  • 56 Answers
This seems to be a problem with the carousel (the part that holds the toners). With the years the bushings worn or it was forced when replaceing a toner. When this happen ussually prints is just one side. This part need alligment and maybe a new bushings. This issue can be fixed but its too complicated if you are not a tech. Try to contact a service center or HP, I think they can send a tech onsite for a fee.
Posted on Sep 08, 2010
I cant take print screen in my hp 540 can u please suggest me an idea
If you hold the Ctl button down whilst pressing PRTSC you will place the screen dump in your Office or Desktop Word or Wordpad programme.
Open Word or Wordpad and right hand mouse click on the blank page, select Paste and there is your Screen Dump. If the data is too large for your Right Hand Mouse Click, press Ctl and V at the same time. That will place the stored screen dump in your Word Processor Programme.
Nov 16, 2010 | Computers & Internet
SIZE OF SCREEN. LETTERS ETC WAY TO LARGE WHO PUT IT BACK TO NORMAL SIZE
Hold down on the Apple in the upper left-hand corner of your screen.
1. Select System Preferences
2. Click on the Displays icon
3. Selecting a higher resolution will make things smaller in the screen.
· As example: x1024 768 icons and text will be large, 1280 x 1024 icons and text will be smaller.
Aug 21, 2010 | Apple Mac OS X
I need to write a letter on computer, not email!! Then print it off and mail Regular mail!!
Please Microsoft Word or Works (two programs available on any system) and once you are done saving the document. Click on file
and then select print .... pls vote for me
Aug 01, 2010 | Computers & Internet
I am trying to print a document in Word and my Phaser 8560 will print it, but there is a blank section on the page (approximately 4 inches wide running down the middle of the page) where the text did not...
Did the document print in full even though it left blank spaces? I f so the problem is The Page Break Occurred before it actually reached the end of the paper. Check what paper is selected on the printer. I don't mean the tray or paper feeder.
On the LCD screen on the printer go through the menu till you find the paper. Make sure the paper is set to A4 or Letter (whatever you normally use.) and make sure this setting matches with the paper select in the documenent.
Check File ->Print ->Settings or Options .... Find out where the paper is mentioned and select A4 or Letter as the case may be.
Hope this will solve your problem
Good luck
luciana44
Jan 06, 2010 | Xerox Phaser 8560N Laser Printer
L7780 won't print on edge of paper
it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Help with my HP laserjet 2840
The HP2840 is a sigle sided scan device. To copy both sides you must copy one side then load the one sided copies in the tray again and repeat the process again. Pay close attention to which side is printed on and scanned on both the original and copies. Also the top to bottom feed order of the auto doc feeder and paper tray. It's easy to get them out of order and copy first page onto last or worse, both sides onto one side of the copy.
The HP2840 isn't capable of scanning both sides and printing both sides at once.
Hope that helps you. If so hit me with a FIXYA. If not hit my user name and further describe the problem to me so I can help you further.
Aug 20, 2008 | HP LaserJet 2840 Printer
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
Happy Laser Jet 4
Hi there you could try the following see if this helps.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on the printer Icon
  • Select Properties
  • Select Advanced located at the top of the window
  • Select Print Processor
  • On Right side of window select Raw [FF auto]
  • Exit all open windows then test
If the same problem repeat above and select different graphic mode. Hope this works for you
Thanks J
Jan 07, 2008 | HP LaserJet 4 plus Printer
Red color alignment problem
1) Whenever a rear projection TV has convergence issues, the
fix involves replacement of both IC's = STK392-110.......sub to
STK394-160E for improved durability...........
2) Soldering only is a temporary "fix" at best
3) Do not allow generic IC's, OEM quality or better = I use
Hitachi brand,made by Sanyo,with no callbacks....
4) Skill level needed = above average,....needs chassis pull...T.
Nov 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
HP LaserJet 2840 All-In-One Printer Logo
156 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
