Question about Craftsman Drills
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears part # is 616478-003.
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Posted on Sep 23, 2010
How to remove a drill chuck from an Hitachi corded drill
How to Remove Drill Chuck
If there is screw in inside center of chuck remove it, it is probably left hand threads so pretend you are tightening it and it will come free. open chuck fully and insert chuck key into holes and hit it with a hammer to remove it.
Oct 07, 2017 | Hitachi Drills
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
Where can I find an owners manual?
may be there change the number try checking thro serial number
May 28, 2014 | Craftsman 3/8" Corded Drill
Calcuation of pitch of the screw and least count?
the pitch of a screw is the distance the thread moves in one complete revolution . OR in the sae measuring system the number of threads (points) in one inch. So if you have a half inch dia bolt and you count the number of threads in one inch along the bolt and you had 20 threads then the pitch would be 20 threads per inch or in metric it is measured as the distance between the points so if the distance between the thread points was 1mm the bolt would be measured as the dia. (say 12 mm) by the distance between the points of 1mm or 12x1.5
Sep 24, 2012 | General Tools Mfg No. 714 Quick Check...
On a 10 inch power compound miter saw, I need to replace the blade. Does the blade bolt have left handed threads? Thanks
Place a finger nail in the thread near the end ot the shaft. If when rotated CW it comes off the shaft it is a left hand thread. My 10" Craftsman radial saw has a left hand thread on the blade shaft.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Craftsman Garden
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I cannot register my new 3/8 inch B&D electric drill as instructe
OK try going to Blacnanddeckercom and in the header you will find a link on the right hand side to register your new tool. Let me know if you need more assistance.
Feb 12, 2010 | Black & Decker Drills
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Drills Logo
466 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
