Question about Garmin nuvi 200W GPS Receiver
2009 Map Update
Here is the support phone number. 1-800-800-1020
Be prepatred to wait 1/2 hour for somone.
The garmin company is big M......F.....
Posted on May 17, 2008
How do I update my shows? And whendo you update your shows??
Netflix Phone Number
Phone Number
888-638-3549
Press 0 at each prompt.
or they call you instead
http://gethuman.com/call-back/Netflix/
Average Wait: 5 mins - 24 hours, 7 days
Oct 10, 2014 | Netflix
LG LN735 updates map
LG LN735 map is compatible with "Desitnator"
Destinator released a 2009.q3 map upgrade.
Not sure if I'm allow to post a link, but if you do a little search, I'm sure you'll be able to find the files.
To upload the files onto your LG LN735, you will need either ActiveSync for windows xp or Windows Mobile Device Center for Vista. (you can download these program for free).
Now just CUT and Paste the map folders off your GPS onto your computer (this way you have some sort of backup). The map folders are located "/residentflash/lge/lgenavi" on your GPS unit.
Now just copy and paste the new map files (Destinator 2009 q3)back onto your GPS. Be warned, this process will take over 3.5 hours.
Reboot your GPS, and enjoy.
Oct 24, 2009 | LG LN735 GPS
Impossible to use `free map update` on s50 3d
2009 update is out of date. We are in 2017 now! perhaps that is why.
Aug 10, 2017 | Navman NavPix N40i GPS Receiver
Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
Sep 17, 2009 | Navman NavPix N40i GPS Receiver
Can not download map update 2009 from garmin pls help me
TO GET 2009 MAP IS NOT EASY! Software update is, from the Garmin site you can update software easily BUT THE MAP... you must purchase for $69.99 OR if you're a technical person who knows the following instructions you can save some $$$
search torrent for
"CNNANT2009-1 MapID 396"
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
I need to install map update 2009 data card
If the map is on a SD card, just plug it into the SD slot on the side of your Nuvi with the power OFF. Then turn on your Nuvi and at the main menu, press the wrench symbol, then the map icon and then "map info". Uncheck your old 2008 map and check your 2009 map and you should be ready to go.
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Magellan 3250 won't update
Hi, I had the same problem with my 3200. Got the update, and it bricked my unit. After 3 weeks of searching the net for solutions, all of which did not work, I called Magellan Tech Support today. Simply told them that I was updating the maps, update failed, and now the unit will not boot past the blue magellan screen with the progress bar. They asked for some information, including the email address that you used to register the product, and the serial number of the unit, as well as the map update information...which you had to register to get the unlock code. They are able to see all of this c in their tests on the unit, which of course did not work. I was then given a RA#, and account #, and was assured that I would get a pre-paid shipping label via email within 24 hours. All you have to do is pack the unit and take it to fed-ex with the label. They will fix your unit with the updated maps, and return it to you via Fed-Ex. Took no longer than 15 minutes on the phone, which beats the 3 weeks of research that did not help. Problem solved. Just call Tech Support, this is a well-known problem, and they will fix your unit and update the map. Hope this helps.
Dec 06, 2008 | Magellan Maestro 3200 GPS
Map Update
I got the chance to talk to 1st navteq and they requested that I speak with sanyo, then I got the chance to talk to sanyo customer service who couldn't offer any help other than asking me to wait till December or January when their version of 2009 map upgrade will be made available.There was one interesting revelation I kind of found out on Garmin 770 too; the same addresses could not be plotted or navigated by this also so I think it is a common factor and these are all somewhat new addresses of new developments. My suggestion will be wait till 2009 map upgrade is made available.
mainoo2005
Aug 24, 2008 | Sanyo NVM-4050 GPS Receiver
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
