Question about Sharp AR-157E Copier
Flashes L 4. Copier does not respond to any effort to get to go beyond L 4
L4 is the main code it should be flashing a second also but I am will ing to bet that there is a scanner lock on the bottom left where your paper comes out that is turned and locking the scanner in place or the scanner itself is gone bad and is around 175 for the part alone\. I work on sharp MFP everyday and these most likely your problem
ComputerDude
Posted on Sep 14, 2010
  • 26 Answers
L4 = Main motor lock When the main motor encoder pulse is not detected for 100 msec.
hi Valerio
Posted on Sep 07, 2010
After Warming up....The error message is E000020-0460..what is the problem
Hello Rama,
I will answer your question however you will determine the solution.This error code means that when your device went through it's "self diagnostics"in an effort to provide you with the optimum image quality a failure occurred.The target for image quality for BLACK could not be reached.The black drum has reached and went beyond it's ability function.Replace the black drum.The part number is 0258B001AA.It is easy to replace and there are many sources on the web.The cost is around 175 $US. . The estimated life of the black drum is 78K.Keep in mind that virtually every image you generate has a black component.The E000020 means one of your 4 drums have failed.The 0460 says 2 things.The 04 means black drum.The 60 that follows means which component of the black drum(the developer)has failed.I am glad to help you and save you a service call.Please let FIXYA know I helped you, and have a blessed life. SPINAL
Jul 31, 2011 | Canon imageRUNNER C5180 Color Copier
Our old Toshiba 3560 copier starts up for about 1 or 2 seconds when turned on, but then the screen flashes blank, and I hear 4 beeps, and that's it. I can't figure out what to do with it, as there are no...
Our old Toshiba 3560 copier starts up for about 1 or 2 seconds when turned on, but then the screen flashes blank, and I hear 4 beeps, and that's it. I can't figure out what to do with it, as there are no error messages. Anyone?
I just had the same thing happen to me. Is there a fix for this?
Oct 27, 2010 | Computers & Internet
Olivetti JP 192 suddenly lost power and will not power up again. Checked miains fuse ok.Tried all equipment off/on. Computer says "Printer not responding" ,of course. Any ideas?
sounds like the power supply has gone.
It sounds like it may be beyond economical repair as it usually is if the PSU goes (usually more effort and / or money) than the printer is worth.
check how much another Olivetti JP 192 is, then decide if its worth repairing the PSU.
Jul 21, 2010 | Olivetti JP 192 InkJet Printer
E-4
There should be another set of numbers after the e4 flashes. E4 indicates a problem with the transfer belt assembly,main drive assy or the drum thermistor. I'm afraid you will need a tech to figure this one out.
Jul 15, 2010 | Ricoh FT5832 Copier
Our Standard SD650 Duplicator has error code SC07-30. The paper tray is jammed in the down position. Need the reset code to clear the error
Through my own efforts & online research. Your service team never responded. I paid for live chat assistance which was not provided, and was then directed to email assistance which has been a complete joke. Please fully refund all fees charged to my credit card. I will look for other solutions to tech problems in the future.
Dec 11, 2009 | Standard Registar SD650 Color Copier
When the copier is turned on the letter H and the number 4 flashes can you tell me what this means please
Hello Karen; H-4 in sharp copier it means fusing unit problem,it could be reset ,the procedure depend on the model of the machine.
Jul 13, 2009 | Sharp Office Equipment & Supplies
Toshiba BD-7610 copier moved the copier down a
take the developer unit out carefully shake back and forth free spin the gears by hand clean any spill inside might work in the future remove dv and drum b 4 moving
Apr 09, 2009 | Toshiba Office Equipment & Supplies
Sharp AR-155 digital copier code H 4
An H4 code on a sharp copier inicates a problem with the heat lamp.Often a bad lamp, sometimes a thermal fuse.You should call a copier service technician.There are lethal voltages in this machine.Good Luck!
Apr 02, 2009 | Sharp Office Equipment & Supplies
E000003-0000
Hello sir; Here have few steps you have to follow;
1, press "*"key,
2, press "2"&"8" at the same time .
3, press"*.".
4, click on COPIER then FUNCTION then CLEAR then ERR.
5, press OK, thenturn power off and back on.
Jan 09, 2009 | Canon imageRUNNER 5000 Copier
Error code: H 4 flashes.. Nothing works
H4 PRESS START KEY THERE WILL BI A SUB CODE LIKE 00.THAT IS HEATER UNIT TEMPERATURE PROBLEM.RESET IT BY THIS PROCEDURE.
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
BY MIAN JEE
Oct 23, 2008 | Sharp Office Equipment & Supplies
Sharp AR-157E Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
