Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Dryer will not turn off...runs through cycly but will not turn off
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Moldy smell on refresh cycly
throw a 1/2 cup or dry baking soda in it and run for awhile . the exhaust will pull it thru the machine and vent outdoors .
May 05, 2015 | Whirlpool Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
My kenmore 110.66512694 is not drying and is not turning off automatically, i have to turn it off myself or it will run forever.
Their are 2 types of dryers. Electronic dryness sensing style and Autodry style. Yours is Autodry.
Electronic dryers have a dryness board which relies on info from moisture sensing bars that the wet clothes rub against. AutoDry models like yours alternates the power between the heating element and the timer motor. This is what you heating assembly looks like:
Check all the components on the heating assembly for continuity.
I have a service manual and more HERE
Apr 01, 2011 | Kenmore Dryers
What temperature should my tromm lg dryer be to dry a load of cloathes
the normal temp cyc's from 140 to 210 but if falls below 120 for any length of time something else is up in the normal cotton selection.
Feb 27, 2011 | Dryers
Wendelyn_quia2how can i unlock the engine key??the key is not turning
try to turning the staring wheel and if that does not work you my need to take the key switch and before you yea right it is easy there should be a hole on the bottom of the key cyc. find you a metal
hanger and push in on the hole that should release the hole key cyc. then you can get your key out
PS you may have to take the bottom part of your dash off to get to your key cyc.
Jan 06, 2011 | 1997 Toyota RAV4
Turns on but no heat
Looking up the model number it says it's an electric dryer.
My professional opinion is that since it is a new dryer and it did work for a while, more than likely your dryer venting is restricted and just enough to cause your thermal fuse to blow in the new dryer. This is a very common problem with electric dryers. Since dryers put out a substantial amount of lint, it is usually moist and it sticks to the walls of the vents eventually they need cleaned out.
Clean your dryer venting, replace your thermal fuse, make sure you don't crush your dryer vent when you put it back in place and I'm sure you'll be back in business.
Oct 26, 2009 | Whirlpool Dryers
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer takes long to dry cleaned vent hear burner go on but not for long thi is a gas dryer kenmore 70 series
to know if the vent is for sure cleaned unhook the dryer and start in timed cyc using high heat and see how long it runs does it run longer than when hooked up to vent if so vent is still restricted if not then the blower housing/lint screen is also plugged
Sep 10, 2009 | Kenmore Dryers
Model# 110.96586210 dryer will not heat up or shut off when running
it will not when the auto cyc is selected if you put in time the timer should advance. but in any case the house fuse should be check first then the heating element,thermal fuse
Sep 01, 2009 | Kenmore Dryers
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
