Question about Whirlpool Dryers
Whirlpool Cabrio Dryer - Mod# WGD6200SW purchased 2/2008. Could you please help me. At first I had a "RF" fault so I cleaned everything out from the back of the dryer, including the body venting,all the vent lines. It still does the same thing, It heats up at the start of the cycle for about 5 minutes and then will not restart(relight) again after this. The dryer runs but will not dry the clothes. Now there is a "F1" fault that appears if I pause the cycle?? Can you help?? The"RF" fault seems to be gone!!
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
Washer_tech
  • 164 Answers
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
Illeagle
  • 525 Answers
SOURCE: I Have a Whirlpool LGR6620PQ0
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_16
You may have faulty gas valve solenoids, especially since you've already replaced the other ignition components. Below is an image, (I hope), of the solenoids which can be found and ordered from the link above. A more rare cause can be a lint filter obstruction, i.e. the screen can be coated with an invisible film from using fabric softener sheets. Try running water over the filter screen, horizontally, and if water does not strain through, then replace the filter and stop using fabric sheets.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
futureloginn
  • 734 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
danromarris
  • 101 Answers
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
Posted on Jan 22, 2009
Check lint reminder flashes every time I turn my cabrio whirlpool dryer on. Is it supposed to do this? I didn't not get a manual when I purchased the dryer
Hi Kimberly, we apologize for what you are experiencing with your Dryer. Please make sure that you check your venting from the back of the Dryer to the outside to make sure no lint is clogged. Also make sure that the lint screen is cleaned after each use. You may visit http://bit.ly/2paVfWu and enter your model number to view your Use & Care Manual. If you check your vents and they are clear and you are still having a concern then please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool Dryers
What does code f24 mean on whirlpool cabrio dryer
Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode. See TEST #4a.
http://dryernotheating.net/whirlpool-cabrio-dryer-error-codes/#F-24
Feb 14, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
Aug 03, 2011 | Washing Machines
How do I get color stains off of the drum of my cabrio electric dryer?
I would try something like the Mr. Clean scrubbing pad. It's not too abrasive and everything I've tried it for has worked.
Jan 12, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Apr 18, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryers Logo
118 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
