Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Clean shot, tool and front carpet sprayers do not spray.
  • Bill Henderson Sep 06, 2010
    We'll see I need to try it.
    President:
  • 1,033 Answers
The area where the jets are located will have to be disassembled to remove the jets and hoses. Most likely the hoses or the jets are stopped up with hardened cleaner/soap. I had to tear into ours and soak the the jets and hoses in a solution of mean green and hot water. After soaking these, I would suggest using a air hose to blow the jets and hoses out. You can use a thin towel to put over the jets and hoses to blow through them but I don't suggest putting my mouth on them. What type of cleaner do you use? I suggest using the cleaner made for it or a mixture of vinegar and water with a top full of fabric softener. The mixture depends on how dirty your carpet may be.
Posted on Sep 06, 2010
  • Nicki M Sep 18, 2010
    I'd suggest starting with the jets and then work to the hoses. The jets are easiest to get to. I used a paper clip to push out the residual cleaner
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Don't know how to use with shampoo
Best to not put shampoo in machine. Put traffic lane cleaner in sprayer with hot water, spray onto carpet after thorough vacuuming, allow cleaner to dwell 5 to 10 minutes and clean and rinse with fresh clean water in machine. For best results do NOT put shampoo in he machine even though it was designed for it. Most of the machines brought in for repairs are clogged with soap gunk. Carpets will be cleaner and stay clean longer because the soap has been rinsed out of carpet
Sep 26, 2013 | Vacuums
Have a Bissell Proheat2 will not spray water from the carpet power head but sprays from tools setting Does anyone know how to get water to spray or clean out water
I had this problem. It was small pieces of debris that got into the solution lines and clogged all the nozzles. There is a nozzle for the handheld attachments, one on the front of the machine for spraying spots and two nozzles underneath just behind the rotating brushes.
It was a royal pain disconnecting the clear rubber hoses inside the machine and blowing out the nozzles and the hoses with compressed air. If you are mechanically challenged I'd suggest you take the machine to a vacuum/steam cleaner repair facility.
I'm not sure how the debris got into the solution system, but it may have been when the dirty water tank was emptied some of the dirty water entered the internal, clean water bladder.
A note to Bissell engineers: This issue can be prevented if you simply add an easily accessable solution and/or water filter that the customers can remove, clean and reinstall. Just a suggestion.
Apr 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
WHERE DO YOU PUT THE SHAMPOO IN THE PRO SHAMPOO MACHINE THERE IS A CONTAINER IN THE BACK AND THERE IS THE WATER BAG IN THE FRONT SECTION
The shampoo solution goes in the back container. The clean water goes in the water bag in the front section.
If you need parts you can find them below
http://www.usavacuum.com/category-s/387.htm
Make sure to give positive feed back.
Thanks. USAVACUUM.COM
Mar 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
No carpet spray
That means that you need to replace the pump belt. Here is a link to the belts you need and the manual:
Bissell 7920 Belts and Manual
Dec 21, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Pump doesn't work
remove the sprayer at the end of the wand clean the tip with a needle then replace
Apr 16, 2009 | Vacuums
Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
325 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
