Question about Refrigerators
We can't find the water filter. I keep looking on the front of the grill for the twisted knob and we don't have on of those! Also tried the back of it. Where else could it be??
  • Refrigerators Master
  • 1,711 Answers
What is the brand and model and year of constraction of your fridge
Posted on Sep 06, 2010
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Where do you change the water filter on the ice and water outlets on the freezer side? model Superba
The water filter for your refrigerator is located in the toe grill at the front bottom of your fridge. it will be slightly left of center as you look at the kick-plate below the freezer door. There will be a knob on the front that will allow you to unscrew it to replace it. Note the knob is removable from the filter and does not come with the new one so you will need to keep it
Bob
Mar 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I removed the front panel (at the bottom) to clean the coils. There is a hole in that panel. When the panel is in place, there is a knob that fits in that hole and attaches, for turning purposes. I cannot...
You have to take front kick panel back off and use knob to take water filter out will be tight but will twist counter clockwise. Then with filter out replace kick panel, then install water filter with knob installed. That should take care of your problem
Jan 07, 2011 | Kenmore Side by Side Refrigerator
How do I remove the water filter to replace it?
If you have a side by side, the water filter is normally located on the front grill at the bottom, also known as a kick plate. You will see a circular area with a handle that is flush with the grill. Simply turn the handle and the filter will pull out. Slide the handle off the old filter and onto the new and insert back in and twist to lock in place.
Dec 08, 2010 | Whirlpool Refrigerators
How do I change the water filter for ASD2522WRS
Your water filter is located underneath the freezer door, in the toe plate grille. you will see a knob, turn it counter clockwise one quarter turn. Sometimes its easier if you remove the toe plate grill first. Remove the filter from the housing, then remove the knob from the filter, place the knob on the new filter, remove the red cap on the other end, and with the "handle" of the knob pointing up and down, insert the filter, and twist it clockwise one quarter turn. Replace the toe grill if you removed it
Nov 09, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How to replace the filter
Take the new water filter out of the box and remove the two red shipping caps on the end of the filter.
The water filter is located on the front panel down near the floor.
Push the release button located just to the left of the water filter grille cap, this will release the filter.
Remove the grille cap from the filter by twisting it counterclockwise.
Reinstall the grille cap on the new water filter.
Insert the new water filter in the refrigerator making sure the words on the filter are the correct side up.
Push the water filter in until it clicks in place.
Flush Water After Installing New Filter
Be sure you flush out the water from the new filter after you replace it! Many readers are having trouble with airlocks because they are skipping this important step. Kenmore recommends you run the water out of the water and ice maker for a few minutes to flush out the new filter. This also helps remove air bubbles from the system. If you don’t do this it’s possible that the water dispenser may not work properly due to an air lock.
This particular water filter claims to reduce:
Cysts and turbidity – linked to gastrointestinal problems
Lead
Chlorine – taste and odor for better tasting water
Sediment – for clearer water
o-Dichlorobenzene – linked to risk of liver, kidney, or circulatory system problems
Benzene – linked to increase risk of cancer and anemia.
Note continue changing the filter on a regular basis.
Hope this helpout....
Aug 01, 2010 | LG Refrigerators
Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Apr 02, 2009 | Kenmore 57029 Side by Side Refrigerator
How do i change the water filter... its at the bottom front of the fridge in the grill part. I tried twisting but i dont want to break it
Push in and twist. If it is stuck you may have to use a little force. Make sure water is off before you use any force, because if you break the filter housing water will go every where
Jul 17, 2008 | KitchenAid Refrigerators
Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Jun 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water filter
Open the freezer door and look in the grill between the bottom of the freezer and the floor. Some might have a push button and twist type, but mine was twist only. It would only twist 1/4 of a turn (until knob is in vertical position), then pull out.
Apr 23, 2008 | GALAXY Microsystems 55622
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
