We have inherited a drayton acl lifestyle lp722 (circa 1998) and have no instructions on how to set the timers. The script inside the lid is of no help.
4 Suggested Answers
  • 1082 Answers
SOURCE: I have just moved to
http://www.heatingcontrolsonline.co.uk/instructions/LP.pdf
Try this link to a pdf - Read with Acrobat Reader
Posted on Nov 11, 2010
hvac1960
  • 2133 Answers
SOURCE: Could you tell me where
Try with this:
cgi.ebay.co.uk/...MANUAL...LIFESTYLE-THERMOSTAT-/200541444128
Helpful?
Posted on Jan 02, 2011
  • 49 Answers
SOURCE: i have a honeywell ST700
If both thermostats only operate as a make break contact then yes they can be interchanged, providing the voltage is the same. If they are battery operated you wont have a problem as the relay contacts will be voltage free.
Posted on Feb 24, 2011
We have inherited a brown/beige Drayton Tempus.seven wall control unit for heating/water but do not have an instruction leaflet on how to rest it etc. Any ideas where we could get even a copy please
The instruction manual for this control unit can be found here:
http://www.heatingcontrolsonline.co.uk/instructions/Tempus7Instr.pdf
Hope this helps,
Chris
Mar 01, 2011 | Heating & Cooling
My central heating pump does not switch off when the acl lifestyle model lp722 central heating timer switches both the hot water and c/h off. pump keeps running through the night
if you can turn off the hw and ch off , to the off postion and it shuts off then the acl lifestyle could needreplacing mine did the same on ch only so changed mine , or check the divtervalve is working and not stuck in the open postion , try turning hw on and off only then the ch see if valve works
Jan 08, 2011 | Heating & Cooling
Could you tell me where i can get a instruction manual for central heating thermostat Lifestyle Model Lp722
Try with this:
Helpful?
Jan 01, 2011 | Heating & Cooling
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Nov 18, 2009 | Honeywell Electronic Programmable...
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Boiler Thermostat
In desperation, I trawled the internet and am pretty sure that these are manufactured by Drayton, either a Drayton Digistat +2 or Digistat +3
Try this page http://www.gasapplianceguide.co.uk/drayton_central_heating_controls.htm
Good Luck!
Iain
Oct 02, 2008 | Hardware & Accessories
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
