Question about LG DLG5932W Gas Dryer
NOT HEATING RLCMAZU@YAHOO.COM - LG DLG5932W Gas Dryer
LG DRYER NOT HEATING ????? ****PLEASE READ THIS LG DRYER UPDATE!!!!! ****
I READ AND FOLLOWED THE SUGGESTIONS ABOVE AND IT WORKED!!!!! AND I SAVED HUNDREDS! LET ME WALK YOU THRU.
(UNPLUG THE ELECTRICAL CORD BEFORE FOLLOWING THESE STEPS)
1.ON TOP OF DRYER THERE ARE SCREWS ON BACK, UNSCREWING THESE WILL ALLOW YOU TO PULL TOP OFF (IT SLIDES AWAY FROM DRYER)
2. NOW THAT TOP IS OFF, UNSCREW SCREWS OFF OF TOP FRONT PANEL (SCREWS ARE ON BACK OF FRONT PANEL BUT CAN ONLY BE SCREWED OFF IF TOP IS OFF)
3. NOW OPEN DRYER FRONT DOOR AND UNSCREW 2 SCREWS UNDER LINT CATCHER AREA, SCREWS FACE THE FRONT - NOW THE WHOLE BOTTOM FRONT PANEL WITH DOOR WILL CAN COME OFF TO ACCESS THE BOTTOM OF DRYER
4. ON LOWER RIGHT HAND CORNER OF DRYER THERE'S AN AREA WITH WIRES AND PARTS - LOOK TOWARDS BACK ALONG RIGHT SIDE OF BOTTOM OF DRYER (ABOUT 6 - 7 INCHES TOWARDS BACK)
(FLASHLIGHT MAKES EASY TO SEE)
5.LOCATE THE FLAME TUBE WHICH LOOKS LIKE AN OPEN CYLINDER (THIS IS A FEW INCHES FROM RIGHT SIDE TOWARDS CENTER OF DRYER) - ON THE LEFT BOTTOM SIDE OF THIS FLAME TUBE THERE ARE 2 SETS OF WIRES (1 IN THE INSIDE OF THIS FLAME TUBE AND 1 ON THE OUTSIDE OF THE FLAME TUBE) THE 1 SET OF TWO WIRES THATS INSIDE OF FLAME TUBE IS WHERE YOU WILL BE LOCATING A "BUTTON OR PIN SWITCH" - THIS WILL BE RIGHT BETWEEN BOTH WIRES (MINE WAS BLACK COLOR BUTTON ON A METAL PIN).
"PUSH / CLICK" THIS BUTTON BUT MAKE SURE THERE IS NO NOISE AROUND YOU BECAUSE YOU NEED TO HEAR TO MAKE SURE YOU HEAR A "CLICK" SOUND - I MISSED IT BUT ONCE CLICKED IT WONT CLICK AGAIN BUT ITS OK CUZ IT WILL WORK).
6. BEFORE PUTTING EVERTHING BACK TOGETHER I HIGHLY SUGGEST YOU VACUUM OUT ALL LINT/ DUST BUNNIES FROM THE INSIDE OF THE AREA YOU WERE JUST IN (AROUND THE FLAME TUBE). i EVEN UNSCREWED THE OUTSIDE OF LINT CATCHER TOOK IT OFF (EASY) AND CLEANED IT. I ALSO VACUUMED THE BACK OF DRYER WHERE EXHAUST COMES OUT AND VACUUMED THE VENT THAT GOES TO WALL AND THE VENT GOING UP TO MY ATTIC AND MADE SURE THE AIR FLOW WAS GOOD THROUGHT THAT WHOLE AREA (SHOP VAC WORKED GOOD CUZ YOU CAN USE IT TO VACUUM BOTH BY SUCKING AND BLOWING AIR INTO THE AREAS WHERE VENTING / EXHAUST OCCUR).
7. PUT ALL PARTS AND SCREWS BACK, PLUG IN AND TURN DRYER ON WITH WET CLOTHES IN IT ...
Posted on Sep 11, 2010
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 06, 2010
The stove is coming on but coils aren't heating. What could be causing that?
Did you check 40A breakers for 220V? Burner coils and lights sometimes are two different circuits.
Oct 07, 2015 | Kitchen Ranges
Not heating
try replacing the fuse that is located in the heating control panel area
hope that works email me and let me no if that works.tevin332000@yahoo.com
Aug 08, 2012 | Miele Rotary B890 Iron
I have an intermittent heating problem with my 1994 (1993) Nissan Maxima 3.0i SE Automatic. Having recently had a coolant leak and refilled the radiator, the heating temperature which was always excellent,...
You definitely have air trapped. Take it to a shop with evacuate/fill equipment where they create a vacuum in the system and then that let's the system **** in the coolant mix and fill all the air gaps. If you go to the yahoo group for villager quest, you will find the procedure to purge air.
http://groups.yahoo.com/group/villagerquest/
Aug 17, 2011 | Nissan Maxima Cars & Trucks
I have a single wide mobile home Intertherm heating / cooling sys. Yesterday it stoped heating . The blower comes on and thermostat seames to be functioning normal , with the exception of no heat . Can...
What is your heating medium?-
Natural Gas, or LP gas--- or Fuel Oil-- Or electric? (Like a Heat Pump-- a compressor as in an Air Conditioning system-- the 'waste heat' is the source of heat-- They are a bit more economical that Electric heat.
Tell us about how it sounds different now, than it did yesterday (or when it stopped heating..)
Are you in the Freezing South right now?
Mack B
Dec 28, 2010 | Intertherm Heating & Cooling
Leak from hose that connects MT641 Heating Tank to Dispenser
It may be a push n lock. If you can send a pic of your phone vam, send one and we can see what's needed. Co7196@yahoo.com. If its a push n lock, While pushing on the line push in the smaller inner sleeve and pull on the line. Make sure there is not pressure in the line.
Sep 22, 2009 | Mountain Plumbing Mountain The "Little...
The heating element has quit working on my dryer
i changed it myself about 6 months ago was pretty easy you can e mail me lhendrix04@yahoo.com
Apr 06, 2009 | Kenmore Elite HE4 Electric Dryer
Our RIVAL Deep Fryer CZF725 heating element does not work. We purhased this fryer at a local WalMart store and only used it three times. WalMart told us to contact the manufacturer directly. HAVE SAME...
These models are not designed well. They are inexpensive, but not durable. I would check the connections at the element. You may have to mark this up to experience. I am surprised Wal Mart will not just replace it. Do you have your sales slip?
Feb 02, 2009 | Kitchen Appliances - Others
2000 nissan quest over heating
you have air trapped in the system.
Go to this site for help
http://autos.groups.yahoo.com/group/villagerquest/
Sep 29, 2008 | 2000 Nissan Quest
Kenmore washer/dryer combo
I Can give you a few things to check if your mechanically inclined, but if you dont feel comfortable digging into the machine I would suggest a technician visit..   if you feel like digging into it send me an email at bigtexan1000@yahoo.com and we can begin
May 30, 2008 | Kenmore 88752 Top Load Stacked Washer /...
LG DLG5932W Gas Dryer Logo
63 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
