Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
We're having trouble with the remotes will open the door but will not shut it. Tried recoding but did not work. What next?
    President:
  • 3,197 Answers
If the main light flashes 10 times when you try to close the door it is a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you can't get both lights to come on you have bad sensors.
Posted on Sep 07, 2010
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
I have a Craftsman keyless gargage door opener model 031D0431. We just moved in and would like directions on how to recode the keyless entry. One more question...if I recode the keyless entry, do I have...
Coding the keypad will not affect the remotes if you follow these directions.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in a four digit code and press enter.
Oct 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work since I changed the code on the garage door opener
thats because you didn't recode the remote to the garage door or you have not recoded it correctly. double check the remotes settings (if it can be changed) to ensure it matches the door opener. Now, if you cannot see any method of changing the remote to suit the main unit, it may be that the remote is factory coded or that it is coded by Soldering links on the circuit board. Carefully disassemble the remote to have a look if it does not have a small bank of switches in the battery compartment. If the switches are there, check the coding is the same as the main unit, if the switches are not there, disassemble and check for solder links on the circuit board. If you are not confident with using a soldering iron, take the remote to someone who is.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Bought new remote tried to pair now only the wall switch works
To program the remotes, hold the button down on the remote and then press and immediately release the smart/learn button.
For the keypad, press and immediately release the smart/learn button and walk over and key in your four digit code and press enter.
Jun 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with my Craftsman 139.53879
when you have to be closer to garage to make remote work tells you battery is going low. Do you have a LOCK or VACATION button. Make sure it is off. May need to recode remotes. See manual for how. Very easy
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work outside of garage it works up close
doesnt work at all or only close. if not at all, recode remote. if short distance, try reaiming antenna wire.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door Ajar Light On, All Doors Closed
not sure what to say but check recall on your vehicle might be a wide problem...could get fixed for free
Dec 02, 2008 | 2003 Pontiac Vibe
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
114 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
