Question about Dual Electronics XDVD8183 Car DVD Player
My dual xdvd8183n player is locked. I replaced my battery and it locked up. What is the code?
I locked my dual xdvd700
well i just figured out this solution. if you have made three attempts and locked up your XDVD700 stereo, all you have to do is unplug your battery for 5 or more minutes to reset the lock. then you will see the uncreen keypad asking for password again. :D
Feb 18, 2010 | Dual Electronics XDVD700 Car DVD Player
It plays some cd
Well this happens because your CD player is region lock, and you need to unlock your player so that it plays all CD's. check your user manual for the region unlock code if the region code is not there then ask to your dealer for that code.
Good Luck!!
Thanks
Sep 29, 2009 | Stanton C-504 Dual Cd Player CD Player
I need the master unlock code for the dual xdvd700
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Sep 04, 2009 | Dual Electronics XDVD700 Car DVD Player
When i start my dual xdvd8181 they ask the password how can i find it. i find password 0000 or 9991 but is not working
You'll have to access Duals web site (good luck) or go to a car stereo installer and ask them $20-40.
Good Luck
P.S. it thinks you stole it...no incorrect code will work and may lock it out!
Jun 23, 2009 | Dual XDVD8181 Car Video Player
DUAL XDVD8181
I need the bypass code for a xdvd8181
Nov 02, 2008 | Dual XDVD8181 Car Video Player
Code
Put in the same number 3 times (example 1111) until it locks and then push in the mute bottom and hold it and while you hold the mute button with your other finger push in the volume control (power button) and hold both of them until a new screen comes up and then put in 122164 and hit OK and that should work.
Oct 23, 2008 | Dual XDVD8181 Car Video Player
I nedd ddx8017 bypass code
I need a unlock code for the kenwood ddx8017 dvd player the unit has locked me out
Aug 20, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Forgot my security code
the guy that wrote how to unlock the receiver left the most important parts out... guess dint wanna be helpful...
Bypass code for radio that our locked
Thank you for your e-mail. Put in the same number 3 times (example 1111) until it locks and then push in the mute bottom and hold it and while you hold the mute button with your other finger push in the volume control (power button) and hold both of them until a new screen comes up and then put in 122164 and hit OK and that should work.
let me break it down you do not need the remote...
first put the same number in (e.g 1111 enter this number 3 times) second after the device locks on the radio hold the mute button while holding that press in the volume nob (e.g power button) hold them both till another screen comes up and enter 122164 and press ok and your all done... this solution works on all dual indash dvd players
Feb 16, 2008 | Dual XDVD8181 Car Video Player
Dual Electronics XDVD8183 Car DVD Player Logo
171 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
