My dvd recorder has been accidently changed in command mode from dvd3 to dvd2 and i cant reset it what can i do?
Click here to get the user guide and go to page # 21.
To add to Benmiur's solution, there are actually a few more steps involved with the OFA (One-For-All)..
Get a One-For-All universal remote that has a DVD key and a
"magic" key, such as the One-For-All-4.
* Select DVD device on OneForAll remote (OFA)
* Hold magic key until double flash on DVD key
* Enter device code 0533
The RDR-GXD500 DVD recorder must be set to command mode
"DVD1", and its own remote set to the same mode like this:
* Switch on recorder and point its own remote at it
* System-Menu -> Setup -> Options -> Command-Mode
* Select DVD1
* Set remote's Command-Mode switch to DVD-1
(it's under the sliding cover)
* Verify that recorder can be switched on and off with
both remotes
Now program function code 189 into button 1 of the OFA
remote like this:
1. Hold magic button until double flash on DVD key
2. Press 994
3. Press magic button (don't hold)
4. Press 189
For some remotes, all of the buttons you need to reprogram need to be
prefixed by 00. So 1 would be '00189'
5. Press 1 - double flash indicates success
Advanced OFA remotes such as the Kameleon have five digit
function codes, in which case, press 00189 for step 4 above.
Now program function codes into buttons 2-5 like this:
* Repeat steps 1-3, then 255 2
* Repeat steps 1-3, then 095 3
* Repeat steps 1-3, then 221 4
* Repeat steps 1-3, then 079 5
Now the actual conversion of the RDR-GXD310 DVD recorder to
region-free:
* Put DVD recorder on standby and point OFA remote at it.
* Press 12345 - "TIMER OK" is displayed, and recorder
starts up
* Press 12345 - Recorder goes back to standby
The RDR-GX310 DVD recorder is now multi-region.
with the indulgence of the others and much tnx to the point-to of Ekse....
You could try borrowing a One-For-All universal remote that has a DVD key and a "magic" key, such as the One-For-All-4.
This was originally posted here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
This is the procedure:
Use the remote to access this
1)Press SYSTEM MENU
the system menu appears
2)Select setup and press ENTER
3)Select OPTIONS and press ENTER
4)Select COMMAND MODE and press ENTER
5)Select the COMMAND MODE(DVD 1,DVD2,DVD3)and press ENTER
6)Slide down the COMMAND MODE SWITCH on the remote so it matches the mode you selected above.
Goodluck,
Please don't forget to rate or accept the solution
1. Switch on recorder and point its own remote at it
2. System-Menu -> Setup -> Options -> Command-Mode
3. Select DVD3
this does'nt work i've tried it its more complicated than that cheers!
no guide on sony dvd rdr-gxd310
