Question about Cobra 25 WX-NW-ST 40-Channels Base CB Radio
I wish to tune and peak a cobra 25 ltd wx. please tell me what pots to turn. I have all of the necessary meters.
    Genius:
  • Cobra Master
  • 1,795 Answers
Do you have a spectrum analyzer? A function generator , bird 43 watt meter,multimeter etc. ? If you have all these then go to www.cbtricks.com and get the information you need .
Posted on Feb 15, 2015
SOURCE: how do you replace the meter light in a cobra 25?
You need to open the unit up ( remove the case/cover). Then remove the 4 screws holding the face plate on. Remove all the knobs ( they slip off) . remove any screws holding the meter on ( there may be none depending on which model you have ) . slide the meter out of the face plate and replace the meter with a new meter. Note: The meter light needs to be reistalled in the new meter. It simply slides out the side of the old meter and slide back in the new meter. Replace all the screws, and the jobs completed.
Good Luck and a good weekend to you.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
ALLEN CLARKE
  • 47 Answers
SOURCE: COBRA 21 LTD WX CLASSIC
purchase and ready made aerial with cable. have you had the SWR checked with your aerial
Posted on Jul 22, 2008
  • 33 Answers
SOURCE: Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Posted on Jul 28, 2009
  • 6 Answers
SOURCE: how do you tune and peak a cobra 29 ltd classic
i would highly suggest you take it to a cb shop to get a cb tuned and peaked. before you do that though, make sure you have a good antenna system. a good antenna will have a much greater effect on your cb than tuning and peaking. as far as output, who knows? it all depends on the skill of the person doing the tuning. be warned that any output over 4 watts is illegal and you could recieve hefty fines if caught with an illegal radio.
Posted on Sep 24, 2009
kb8dns
  • 494 Answers
SOURCE: i just purchased a connex 3400hp and my cb freinds
The Cobra 29 has always been a good talking radio and is preferred by truck driver mainly for that reason! The Connex is a great radio in it's own right but sometimes needs a little help. I would suggest a power mic and there are many to choose from but Astatic is a clear winner! My two cents for a suggestion!
Posted on Mar 07, 2010
How do I turn up the the dead key power on a crobra 25 ltd cb radio
There is no adjustment to turn up the carrier power in a Cobra 25 LTD. The AM Cobra's are not like the Galaxy's in that respect. All you can do is tune the output section for maximum on a meter.
Jun 21, 2014 | Radio Communications
How to tune and peak a cobra 18WXSTII
should never tune.they are tuned from the factory.Now peak thats different.The only thing you can do is turn the watts up or down and turn the mod vr up. you need a meter to do this.A schematic will also help.now have at it.
Feb 06, 2014 | Cobra 18 WX ST 40-Channels Base CB Radio
Meter drops when pushing mic
some one tuned their radio to the wrong side of peak and now you have downward modulation .Try re-tuning it back to to its original settings and if you get it back don't mess with it unless you know what the shell you are doing.
Sep 30, 2012 | Cobra 25 LTD 40-channel Classic CB Radio...
My 25LTD CB has been tuned and peaked. I just replaced the meter and it spikes hard when keyed. How can I adjust it without degrading the tune?
It could be the variable resistor that sets the meter movement or it could be the person that tuuned and peaked it didn't know what they were doing and set a high dead key. The radio should key low and then swing high. You must first track down which one is the problem. You will need a good watt meter for that. If it isn't a problem with too high a dead key then go to CBtricks and look up your model of radio and find the "VR" variable resistor that sets the meter. Open up the radio and turn the resistor to match the meter scale with what the watt meter reads.
Sep 16, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
Size fuse for cobra 25 ltd wx
hi please insert a 6amp fuse on the dc positive line it will work fine with this
Nov 04, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
How do i tune my cobra 29
Depends on what you mean by "Tune"
If you are talking about aligning the radio, you need the factory service manual, a watt meter, volt meter and oscilloscope to align the radio.
If you are talking about a peak and tune, that all depends on what you want. If you are just trying to peak it out, the easiest thing to do with out having to know about what you are doing is to turn the modulation to max. In that radio you do that by turning VR4 all the way to the left. That will get you around 20 to 25 watts of modulation.
There is more you can do, but it gets technical. But over all you will be pleased with just the modulation increased.
Some times people have the radio tuned to be run on an amp, which is necessary so that you do not blow up the amp. This involves un-soldering parts and replacing them with other parts to achieve the desired dead key.
Oct 19, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Not enough audio and i dont want a power mic i
Take off the cover, you will need a watt meter or mod meter to do this. On the circuit board, part side up, look for D11, and cut one end of it, hook up meter, key the mike and with a peaking or tuning tool, while saying aaahhhhhhh in a long and steady voice, tune L12,L13,L14 for highest peak, you can get the tool there also..put cover back on and enjoy.....hope this helps...
Jun 03, 2010 | Cobra 29 LTD CB Radio
Jul 28, 2009 | Cobra 29 LTD CB Radio
Cobra 18 wx st rf/s-meter does not function
to be sure that u dont burn yr radio try to check yr swr with an external meter to be mounted between the radio and the antenna and check if it works! good luck.
rgds stefano
Dec 25, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 ltd classick tuning
Here is a link to the Phantom CB's seb site, you can click on the brand of radio you want to peak, in you case, Cobra. Then follow through the chart to the Cobra 29 LTD Classic under the Cobra power mods, which tells you what to adjust and changes that can be made. Only one suggestion I have before you start, where it says to cut D11, don't, only turn up VR-4 for your modulation. That is the only thing I don't like with their instuctions is telling people to cut the modulation limiter. You can get full modulation by turning up the potentiometer, and if you cut the limiter, sometimes it will over modulate.
http://www.714xpress.net/714mods1.html
You need an inline power meter to peak the radio out. This is the quick and dirty way to peak and tune a radio. To properly align a radio, you really need an oscilloscope and other related test equipment.
If you have more questions, don't hesitate to post here or email me at rollincbmods@yahoo.com. I can't promise I will have an answer to all questions, but I will do the best I can to help.
Dean Pitts
Rollin CBs
Nov 20, 2008 | Cobra 29 LTD CB Radio
Cobra 25 WX-NW-ST 40-Channels Base CB Radio Logo
407 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
