Question about Technics Audio Players & Recorders
I have a Technics SA-gx550 receiver and it i turn up the volume it shuts off and the red overload light comes on.
Wich is low imp in my technics sa-gx550 please tell me?
Posted on Nov 24, 2010
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
I have a technics sug91 amp the over load light comes on what can i do to remove it
you cant remove the overload light. it does that as a safty so you dont burn up the amp when its not being used properly. do u have a capacitor? are the speakers ohms and watts the same as the amp?
Oct 18, 2009 | Technics SA-AX540 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
No, its my Technics SA-GX550 amplifier - have a problem - HELP!!
Im having the same problem with mine. The problem seems to have started after I placed a vcr on top of the unit. I am thinking that It may be getting too hot. But don't really know.
May 05, 2008 | Technics SA-DX750 Receiver
599 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
