Question about Maytag MSD2756G Side by Side Refrigerator
I am looking to find what is clicking sound from my fridge, which is maytag side by side, it makes snapping sound every 2 min. & 2 second later click again, I opened the back it looks like the sound comes from the square white plastic behind compressor or from a square black plastic it has # 99-39m & two wires attached to it.
  • Maytag Master
  • 43,501 Answers
That sound is the sound of the compressor trying to start and being unsuccessful at it.. the relay closes ( first click) then the compressor does not start so the overload relay opens again, (second click) in two minutes it cools off and the process starts again...
The problem could be a terminal problem in the compressor or it could be a bad start relay and capacitor problem....I would try changing the relay and cap first....if that don't work rhen you have major problems.
Here are a couple of tips that I wrote about this that give much more deatil about the problem...
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
I have a Maytag side by side, MSD2434GEW, about 8 years old, the fridge side appears to be working fine, the freezer side is about the same temp as the fridge and not cold enough to freeze anything. It...
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
Dec 03, 2010 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MFC2061HES Not cooling Either Fridge or Freezer
Replace the relay on the compressor and it should start working.
Jan 12, 2009 | Maytag MFC2061HES Stainless Steel French...
Fridge making a humming noise every 3 min
check and see if compressor is running it is in the rear behind the cardboard cover if it is super hot then you need to get a tech out to look at it and it may still be under warranty
Jan 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MSD2756GE Side by Side Fridge
You have a bad compressor, time for a new refrigerator. Check your warantee for compressor failure. Might be 5 years.
Dec 31, 2008 | Maytag MSD2756G Side by Side Refrigerator
Fridge making "knocking" noise
Remove the light shield and there should be screws under it. Remove the air tower in the back, it snaps in and there is 2 screws behind that as well to remove the damper housing that sits behind the light. Also not sure what your model is but some models have 2 air ducts that run up each side, they come out after the light shield is removed by sliding foward and then pulling down. After the screws are removed in the upper plate the light assy will snap out and there is 2 quick disconnects on the wires.
Jul 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge is not cooling at all there is a clicking noise every 30 secs to one min. the model number is ptb1553grw
it sounds like a bad:
  •       start switch (on the side of the compressor) or
  •       compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps
(bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 14, 2008 | Maytag Refrigerators
Maytag refrigerator clicking
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 06, 2008 | Maytag 23 cu. ft. Side-by-Side...
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MSD2756G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
