Question about Samsung SyncMaster 172N 17" LCD Monitor
I have s Samsung SYncmaster 172N digital montior. After bootup, the screen can stay on anywhere from 5 to 25 minutes and then turns off. All power mangement has been set to not turn off monitor. No keytstrokes will bring monitor back up. After being shut off for a half hour it will then come back on for a short while. I am using a NVIDIA Geoforce card. Any ideas?
  • 11,361 Answers
It sounds like you have thermal problem, try it with another PC first, if it still does the same, then you should look for cold solder joints, caps with leaking/bulging tops.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 07, 2010
Samsung syncmaster 172n inverter
http://www.radioradar.net/en/service_manuals/monitors_circuits/mstar_semiconductor_samsung_en.html
Jun 21, 2014 | Samsung SyncMaster 172N 17" LCD Monitor
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung syncmaster 920BW - the screen goes white - no adjustment controls work - any idea what is the problem? Thanks.
Look to see if the T-CON board on the LCD panel is getting the 5vdc feeding it, it may have blown fuse on the T-CON board due to short circuits.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jul 16, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Syncmaster 172n will not power up. Is there a fuse somewhere?
Sorry, no fuses. No user serviceable parts. Take it to a reputable repair person or check my website www.micromendllc.com.
Mar 02, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Image does not fit screen
Set your setting to "Secondary Screen Only"
As your setting for both screen doesn't seems to be adjusted but you can try turn it off.
Jul 26, 2017 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung syncmaster 172n monitor has a fuzzy screen when turned on
the transistors on the display may have been affected due to power surge inside..please call in for a repairman before it gets magnified into a big problem
thankyou..
Aug 13, 2008 | Computers & Internet
SAMSUNG SYNCMASTER 172N
Try to unplug the monitor on your pc then you if you see no signal there is no problem with your monitor maybe the problem is the graphics card or the driver installed
Jun 02, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Monitor
is your monitor connected to any system? beside the power supply? Try to check the connections.. you may need to explain further of the system that you are using....
Aug 20, 2007 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung SyncMaster 172N 17" LCD Monitor Logo
62 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
