Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Bissell 9400 Carpet Cleaner
You sound savy with Tech details so I'll give it a shot. The other day I was cleaning the carpet and somehow picked up a rubber duck between the rows of brushes. I heard the machine struggling so turned it over and removed the quacker. Anyway after a thorough inspection of the machine the unit only turns the brushes for a second then stops. I pulled apart the brush assembly, belt looks fine, everything spins ok and is in clean working order but same result. I turn on the machine, tilt it back and the brushes spin for a second then shut off. I let the unit rest for a couple days and tried it again, same thing. I would guess if the brushes do spin the motor must be OK. The motor shuts down and is not moving after 1 second, is it a circuit problem? Any help would be appreciated.
  • 417 Answers
I have a Bissell 9200 Proheat 2x with same issue.
theres a circuit board in the handle that controls the DC brush motor and a handle release switch near the back wheel. Its either the motor, circuit board or release switch, Ive isolated my brush stoppage to the circuit board by testing. If your handy at all you can test to see what it is. Begin by disassembling the handle by removing several screws, be careful as there will be two different lenghts of screws, inside the handle is the dreaded circuit board brain screwed to the back handle attached with four wires via connector. the grey and black wires go down to the motor and handle release switch (theres a switch that stops the brush motor when you put the handle up in the bottom by the wheel), yellow and red wires are 120 volts form main switch, use a circuit tester to check for voltage from yellow and red and switch to continuity to check if the motor has an open circuit or busted handle switch. I suggest using a digi cam and take pics of disassembly and masking tape to mark hoses if your going to disassemble the bottom. FYI Bissel will not let you order that circuit board but will let you order the motor, I dont know about the switch. Looks like Im going to build my own circuit board from radio shack parts , Im not sending my Bissel back to Bissell, I could go on and on about that LOL.
J Meredith
Posted on Jul 09, 2008
  • Jude Meredith
    Jude Meredith Jul 09, 2008
    hi,
    bissell circuit board part # 002-2036805
    good luck!
    J
  • Jude Meredith
    Jude Meredith Jul 11, 2008
    hi,
    I made an error with wire color, the yelow wire is not servicable it goes straight down to the bottom, its a white and red wire that are 120v. I will be ordering a new motor and circuit board, I dont recommend trying to go to radio shack to make a replacement, the circuit board has a high limit safety which stops the motor if you run over an obstacle and you risk blowing a belt. If you bypass it, youll ruin the motor. Bissell will refer you to a vac store to have them fix it..
    J
    President:
  • 1,673 Answers
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
Posted on May 13, 2008
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell carpet cleaner won't dispense the
heatman101
fdghd
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell ProHeat Plus carpet cleaner does not **** up water
heatman101
dghdgh
Jan 04, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell carpet cleaner
heatman101
teydh
Nov 30, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Carpet Cleaner Won't Release Solution...
heatman101
h
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The carpet does not look like it is clean
heatman101
dhgjdg
Mar 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes do not turn
You should see if the brush belt is broken. I broke mine you can find the part at walmart or on bissell.com
Sep 02, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
552 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
