Question about Hotpoint WF430 Front Load Washer
Hi, How do I change a drum bearing? - Hotpoint WF430 Front Load Washer
  • 4,348 Answers
This repair takes special tools, get an appliance guy to do it.
Posted on Sep 06, 2010
Tdc62
hi push the top of drum at back in side upwards if it lifts bearing is worn if so take cover of back remove wire pin to change bearing
Mar 13, 2013 | Hotpoint TDC32 Electric Dryer
Noisy drum, grinding sounds when the drum is spinning
Hi
The grinding sound is because of damaged or broken bearings.
You will have to see if the motor rotor bearing is damaged or the drum bearing before you change anything.
Regards
Berry
Feb 07, 2010 | Zanussi FS1155W Front Load Washer
Hi, My name is Atanas, I am trying to change bearings on our Ariston avd149. I just found out it is not possible to get out the inner drum. How do I support the inner drum with the axis when putting the...
I needed mostly advice on how to put back in place the shaft of the inner drum in the bearings without using a hammer... Now I found solution on this- just use a screw bolt. Hope this works…
Thanks
Nov 16, 2009 | Ariston Technologies AW 149 NA
Hi, there i a knocking noise during the spin cycle on my hotpoint aquarius 6kg wma56 washing machine?? How do i fix it?
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Nov 12, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, I need to change the drum bearings on a Hotpoint WM64N washing machine - anything to be wary of?
it is very tedious to change drum bearing but if you are technically sound than you can do it. but you won't find the water seal any where other than the sevice center, in case seal is damaged.
Oct 24, 2009 | Washing Machines
Change Bearings for HotPoint WMA62N
Hi, I also have the bearing problem on a hotpoint wma and have just stated the repair job. I have found the following on different forums, so maybe it might help others. You do need to remove the drum and there are two different sizes of bearings 30mm and 35mm. To find the size you need you have to get to the bearings and measure them.
. Ok,Hotpoint wma series drum bearing failure.Firstly very common problem since i work on these things every day-i think there is a design fault-nothing new in this trade!What follows is
the sequence of problems in changing the drum bearings:If the machine has been thrashed into oblivion just changing the oilseal/bearings will have you back to square one within a
couple of months since you would`ve damaged the drum shaft as the bigger bearing of the 2 goes into shapnell mode!So you`d best change the drum shaft(in the trade known as the
spider) however this thing is aluminium usually held onto the the drum via torx headed screws either in steel or soft Al2 also-forget it as your not going to get these out unless your mega
lucky,what we do at work is to replace the whole tank/drum/bearing assembly which comes with a new element and belt ie the whole tank unit,the trade price of this part is less than
£100.00-you can draw your own conclusions as to the retail price as you wish.If you haven`t thrashed the machine you can get away with replacing just the bearings or easier still the rear
half of the tank(trade price 30.00+vat) in which the bearings are already fitted via the factory and reuse the existing spider/drum shaft so long as it isn`t damaged by disintergrated bearing
shapnell.I hope this clears up this problem for you.Please note that this machine`s filter which is at the rear doubles up as the air trap-the oval section 8" long semi transpatent plastic tube
thing-the part that allows the water to compress the air so turning off the level of fill at the right level via the round swt behind the soap dispenser-called the pressure swt-if the filter gets
bunged up the machine o/fills and either overfills or overfills and floods or tries to spin with aload of water still inside the drum or perhaps no spin at all.Hope this helps someone.
The drum comes out through the front on this one. Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band
holding door seal & peel seal back. Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side & slide to right to remove being careful with board &
wiring. Remove screws holding top end of front then lift slightly &remove front. Remove back panel & take wiring off heating element & pump. Disconnect the pump hose at the drum end,
disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then
carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
Mar 11, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint motor problem after renewing drum bearings!
Hi dave, Its nothing you have done! It will need the carbon brushes changed in the motor as they have got low. The arcing is caused by the brushes not touching the com properly. Just change them and it will be all good.....
Mar 07, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Hotpoint WF430 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
