Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
What does "low flow" mean? Thx - Intex Automatic Salt Water System for Above Ground Saltwater Pool
    President:
  • Intex Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The flow of water thru the flow meter is too low and the generator is not working because of that. Cleaning the filter is usually what is required to improve the flow rate. If that doesn’t solve the problem look for obstructions in the plumbing such as clogged or full skimmer baskets, full strainer baskets on the pump inlet or some other blockage. Once the flow increases the error should clear itself and the generator should start to work.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 07, 2010
Palio 1.2. Why is there no oil pressure?
Very low or no oil pressure reading does not necessarily mean the oil pump is not working and if you replaced the oil pump because of low oil pressure does not mean the original pump had necessarily failed. It may have but it may not have. Oil pressure is not created by the oil pump but by the resistance to oil flow. If you have very low resistance to flow you will get very low oil pressure no matter how well the oil pump is pumping. If you have a very worn engine, especially the bottom end main bearings and conrod bearings, tolerances increase very significantly, there is little resistance to flow and you will achieve very low oil pressure and metal parts will touch. Oil flow to the upper part of the engine may also suffer. If your engine is gummed up with oil sludge due to too few oil changes some oil passages may be blocked as well.
Sep 21, 2015 | Fiat Cars & Trucks
Code p0102 in a 2001 Cadillac sts Seville northstar engine wat does it mean
Code p0102, according to:
P0102 Cadillac Mass or Volume Air Flow Circuit Low Input
is "Mass or Volume air Flow Circuit Low Input"
Means that the computer isn't getting enough signal from your MAF sensor.
Check the link above for more information. MAF replacement isn't difficult.
Jul 10, 2015 | Cadillac Cars & Trucks
08 equinox low heat
Low or poor heat usually means your thermostat is stuck open. To check with a cold engine, remove the rad cap and start the engine look inside there should be no water flow, if its flowing the stat is open.
Mar 14, 2015 | 2008 Chevrolet Equinox
What does lo mean on my h250 hayward pool heater
LO standss for limit open. the most common cause is lack of adequate water flow through heater. other causes are high temp limits.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
  • Low water levels
  • Dirty filters
  • Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
Dec 24, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
I have 4 codes: 1- p0401 2- p0401 Pd 3- p0403 4- p0405 what do I have to do to get rid of these codes. what are these and where are they located on a 2004 grand am Thx
p0401
Exhaust gas recirculation-insufficient flow detected
p0403
Exhaust gas recirculation-circuit malfunction
p0405
Exhaust gas recirculation vave position sensor A- circuit low
hope this helps. not sure where they are located
Aug 27, 2010 | 2004 Pontiac Grand Am
Want to know engine light p0102 code means
P0102 is the generic DTC (Data Trouble Code) for (Mass or Volume Air Flow Circuit Low Input), and it would most likely be a fault with the MAF (Mass Air Flow) sensor.
The MAF sensor could be dirty or faulty, and there might even be restricted air flow to the MAF sensor (like a plugged up air filter). Also be sure that there are no air or vacuum leaks in the air induction system especially between the MAF sensor and the throttle body and that the hose clamps on the air induction system are all tight.
Jun 08, 2010 | 2001 Chevrolet Venture
Check engine light low air flow
I assume you mean EGR low flow P0401. This is ging to be a faulty EGR dpfe sensor or the ports i nthe intake are clogged behind the EGR valve.
Mar 16, 2010 | Ford F-150 Cars & Trucks
Maytag washer mod # MAH9700AWW shows a fault code of NF could you help in any way Thx
means no fill, continuous fill of 12 mins. generates this. check water valves. if you do actually have proper water flow in and are getting this then check level sensor. a full tech sheet is avail at servicematters.com with info on checking components.
Jun 03, 2008 | Maytag Washing Machines
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
309 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
