Question about Garden
How do you release the locking feature of the Delta MS450 compound miter saw so you can raise the "arm" and make a cut? It's currently in the "down" position and I can not raise it. Thanks.
  • 377 Answers
By going to this web site you can down load the users manual and identify the release pin.
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=61202&typeId=12284&documentId=29461
Posted on Sep 06, 2010
  • pwillitz Sep 06, 2010
    Where the saw pivots on the table itself, there is a pin sticking out on the right side. You need to push down on the saw lightly and pull this pin out. That will release the saw.
    Do this with the saw unplugged.
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
How do I release the arm of a radial arm saw to cut miters?
Near the blade there should be a clamp that allows the saw head to be tilted to cut an angle miter through the board. The other miter adjustment is a clamp at the top of the post to let the radial arm swing at an angle, this would be used in conjunction with the other adjustment to cut a compound miter. I hope you are not totally confused now.
Jun 09, 2010 | Saws
I do not know how to release the blade so it will come up on a ryobi TS1342 miter saw.
When you are facing the saw look on the right hand side in the area where the arm pivots. There will be a silver shaft with a groove just in front and slightly lower than the pivot. If you hold down slightly on the handle and pull out on this shaft it will allow the arm to lift up. Locking the arm down is reverse.
Here is a link to the owners manual for this tool.
http://www.ryobitools.com/product_manual/file_url/378/TS1342L_329_eng.pdf
Feb 24, 2010 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I borrowed a chop saw and it is in lock position, how do i release it
on the back of the saw where the arm goes up and down there is a pin that pushes in it will only stick out about a 1/2 inch.
Feb 23, 2010 | Hitachi C10FSB 10" Sliding Dual Compound...
HOW TO RELEASE DELTA MITER 250 SAW
All miter saws I've dealt with, there is some sort of peg located on the back arm close to the hinge. However, the arm is spring loaded so you may need to press down on the front of the miter saw to relieve pressure on the pin (peg) to allow you to pull the pin out and release the saw arm. I hope this is the answer you are looking for.
Dec 27, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
HOw to lift the saw in the up position
i have a bosch   it has a little knob on the side that i pull and give a half twist and release   then the arm will raise and fall until time to store it again
Nov 07, 2009 | Makita Tools 12" Compound Miter Saw -...
Can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
Feb 20, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
