Question about Toshiba 50H72 50" Rear Projection Television
Can you transport it by laying it on its side for a car ride to move it?
  • Toshiba Master
  • 8,457 Answers
No,this tv have chemicals,it sides could destroy those sensetive chemicals,causes it to distort ur DLP CRTS tubes or worse cases chemicals leakage to the circuits boards,destroy both DLP CRT tubes and circuits boards together.Best way is to tranport it up right.
Posted on Sep 06, 2010
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
I recently purchased a Terminator 2 - Judgement Day arcade game. Is there a special way I should transport this? Can I lay it down, or should I stand it up? Can I just unplug it from the wall, move it,...
Check that everything is tightly in place before trying to transport your machine. Lay it on its side or back, and make sure you pad all sides and secure it. When you get it home, everything should work fine immediately on plug in.
Mar 07, 2011 | Terminator 2: The Arcade Game
Moved unit, wont get cold
did you transport it upright or laying down.... depending on who you talk to you will get a different answer... i have been in the appliance business for 18 years and have to say the more i hear they are transported laying down the more i hear troubles... either way after transported or moved they should be left sitting for approx. 24 hours to allow all the oil to settle back down,,,also could have developed a leak in the sealed system one of the refrigerant lines leaking.
Feb 14, 2011 | GE Refrigerators
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
SELL TV: HOW DO WE MOVE IT
Howdy,
The best way to transport the TV is standing up with the front secured to a 'side' of vechile. If you don't have that choice lay the TV down on it's face. With both make sure you have plenty of moving blankets.The side would be my last resort because of stability. DO NOT LAY ON BACK!!!!
Good Move, big IRISH.
Dec 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Can lay the rear projection TV on its side when moving?
I would not lay it on it's side unless there is no other option. Then I would be very careful. TVs should be transported right side up.
Nov 08, 2009 | Hitachi 50UX57B 50" Rear Projection...
Is it ok to transport a refrigerator on it's side?
Not true. Refers since the 1950's are sealed units but for safety's sake let it sit for awhile after you move it.
Aug 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's back..it is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
Panasonic PT-51G44 51 transporting?
No you should only transport it standing up to ensure the optics do not get messed up. I have seen peeps do this and nothing happens. I have also seen pros do the move on the back or the sides and it tears up the TV set. Good Luck
Aug 30, 2007 | Panasonic PT-51G44 51" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
