Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Fires but will not continue. fresh gas, plug's ok. ???
    Brigadier General:
  • 4,088 Answers
Does the primer bulb fill with fuel after several pumps? Check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines. Make sure the carburetor fasteners are tight. Is the fuel properly mixed with modern synthetic saw oil (50:1 ratio)? If no help, go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope some of this helps!
Posted on Sep 06, 2010
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Mcculloch eager beaver chain saw
Hi Mike firstly check the air filter is clear and if so try putting some fresh gas where the spark plug goes into the block. If it fires its the gaskets on the carb. If it doesn't it's the gaskets on the block and it wont fire due to the compression being at fault.
Oct 20, 2013 | McCulloch Garden
I am pushing gas pedal it wants to start but just doesnt' seem to fire up
It is fairly hard to diagnose from this,but I am assuming that it ran ok the last time you ran it.It may be flooded.hold the gas pedal to the floor and crank the engine.Do not be tempted to lift your foot or pump the pedal.It may have to crank for 20 seconds or more,but it should begin to fire up, first 1 cylinder,then 2 etc,again do not lift your foot until it is firing on all cylinders and revs up cleanly ,then lift but keep it revving a little until all gas is cleared and the plugs arent fouled.
hope this helps or get back with some more information
Mar 27, 2011 | Nissan Sentra Cars & Trucks
Back fires and rough engine
Drain your fuel tank first. Then mix 50/50 parts mixing oil and fresh gas. Put fresh gas into the saw as well as putting in a new spark plug and start it up. Stale gas (gas that has sat in the tank or gas jug for an extended period of time), bad gas or water in the gas will cause it to rough idle and back fire.
Nov 14, 2010 | Garden
Mower will not start,changed plug,new gas,has fire to the plug still will not start,backfires once in a while checked the fues it is ok,it is a lx460 mod# 13AX60RH744, cleaned the points etc,
Replace the air filter. Remove the plug and try to start it. If you don’t smell the gas your problem is fuel. Most have a primer button that needs to be pressed 3 times. Remove the air filter and press the primer button to see if you squirt fuel. If it has no or little smell, continue priming and starting until you have fresh fuel. Replace the filter and plug. Disengage the pto ect ( saftys)before starting. Here is the manual Don’t forget to follow the safty startup list.
http://www.dixiesales.com/ipl/339/13ax60rg744_operators_manual_02_22_06.pdf
Aug 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
On lpg vehicle backfires and blows intake pipe to pieces
Hi LPG is very dependent apon plugs and lead quality, the first thing to do is replace them both with new, it may very well cure the fault.
Jan 31, 2009 | 1994 Land Rover Discovery
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Leave blower and vac
I don't mean to over simplify this, but are you using fresh gas? Gas blowers and string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. Not just fresh from the can, but fresh from the pump! And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers and blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 04, 2008 | Craftsman 4 Cycle Blower/Vac
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
145 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
