The camera got stuck at one position. It will zoom but won't pan and tilt. Replaced the camera with new one. The new camera when installed, moved around and found the home position but is now just resting there. It does not pan or tilt either. Your help is appreciated.
-   we had the same problem with 4 camera bought 2 years ago. All the 4 cameras give the same problem when the tour is activated. After viewing log we found this error repeated "recieved a error packet in CamSendRecvPtzPosInc". The firmware is 2.24
-   bitdegenerat
Solution #1
posted on May 22, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
power supply weak.
Solution #2
Guest
Rank: Apprentice
Rating: 0%, 0 votes
power supply weak.
Solution #3
Guest
Rank: Apprentice
Rating: 0%, 0 votes
power supply weak.
Popular Solutions for Sony SNC-RZ30N Network Camera
can not send mail through isp for sncrz30 There is no option to add user and pass that the isp...
(More)
can not send mail through isp for sncrz30 There is no option to add user and pass that the isp requires so if you want to send an image automatically it fails can not contact server Later models have a radio button Are we stuck with this?
System log shows, "SMTP Server was disconected". Trying to send to either Gmail server or...
(More)
System log shows, "SMTP Server was disconected". Trying to send to either Gmail server or GoDaddy. Neither seem to work. Is there something on my PC that needs to be enabled to make this work?
After i used FTP way to upgrade it , then whatever i try to use LAN enviroment , i still can't...
(More)
After i used FTP way to upgrade it , then whatever i try to use LAN enviroment , i still can't connect my Sony webcame Snc-RZ30N, what any way can make me connect it ?? please who can give me a favor?
