Question about Refrigerators
Need the manual for eurocold chest freezer c4cfw-h as there is a switch on the front and we do not know whether it's for fast freeze or the on/off switch
SOURCE: Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: whirlpool 10cube chest freezer red light
yes.
Posted on Oct 07, 2007
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
wheelshot
  • 102 Answers
SOURCE: Buzzing noise -Kyoto KU 9577 Freezer
you may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
Posted on Apr 11, 2009
woodchuck789
  • 4059 Answers
SOURCE: Hotpoint Freezer Chest
Is the compressor motor running. It's around back underneath behind the cardboard cover. If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 11, 2009
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
The freezer freezes two hard , there are 2 switches on it are they both suppose to be on?? one is orange and one is white.
Well hello...on your freezer...the orange switch is for "fast freeze" and should not be on constantly...only when you want to freeze items really fast.If you have it on...turn it off.Also do you have the temp control set at maximum...If so...try to reduce the seting by one number.If not...leave it as is.Give the freezer about 24 hours to re stablize.That should do it...also...you will notice a reduction in your electric bill as the fast freeze switch causes the unit to draw a greater amount of electricity..MAKE SURE the orange switch is off...I hope this was helpful....PEACE...
Jan 05, 2012 | Haier 7.3 cu. ft. / 207 liter Chest...
An orange light is on next to the green light on my chest freezer
Normally orange signifys that the machine has been switched into fast freeze , check your controls
Sep 04, 2009 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Refrigerators Logo
254 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
