Question about Freezers
Beko frost free fridge freezer stopped working not freezing and fridge warm. Light still working and making a noise. Black cylander at back of fridge is burning hot and there is a leak.
  • evelyncoutts Sep 07, 2010
    Hi
    The leak you asked about is water coming from the bottom of the freezer and is running into a tray above the black cylander.
  • 50 Answers
What kind of leak? Water or freon?It sounds like your freon (refrigerant gas) is leaking out. Switch it off and get the repairman in. You do NOT want to burn the motor out. Re-gassing and soldering a leak is much cheaper than replacing a motor.
Posted on Sep 06, 2010
  • Freezers Master
  • 17,970 Answers
I have a beko fridge freezer did the same thing the next door neighbor is a service engineer for Hotpoint he had a look and said that the floor the freezer was standing on was not level and to move the freezer away form wall 2cm and leave switched off for 24 hours then switch back on. He said that the auto defrost pipe on the back was pinched by contact with the wall and had frozen. We did as he said it worked ok then.
One thing to bear in mind with many fridge freezers is that, surprisingly, you can actually locate them in an area that is too cold!!
This happens in cheaper models with only one compressor and one thermostat (located in the fridge section). For example some people put them in a garage or outbuilding. If the room temperature is between, say 5-10 centigrade, the compressor rarely runs and the freezer contents therefore warm up too much!
What happens is that cheap fridge freezers have only one compressor and one thermostat which serves the fridge and the freezer sections simultaneously. (More expensive models have two compressors and two thermostats - one for each section and don't suffer this effect).
The thermostat is located in the fridge. If the room temperature is, say 5 degrees centigrade (Think garage in winter time) then the compressor won't run because the fridge will already be cool enough. Unfortunately, this means that the freezer section will not receive any cooling either. The result is that the freezer, which should be around -20 degrees can warm up. In winter, this can lead to the freezer contents spoiling.
In an ordinary room, where the temperature is, say 19 degrees, then the thermostat will make the compressor run to cool down the fridge. At the same time, the freezer will be cooled. In this case, the compressor runs long enough to keep the freezer at -20 or so.
I know it sounds ridiculous, but it does mean that the room can be too cold for a fridge freezer to run properly. Hope I explained that well enough .
Hope this helps.
Posted on Sep 07, 2010
  • ZJ Limited
    ZJ Limited Sep 07, 2010
    Check the condensor fan if that aint it unit may be low on charge; have
    you checked the door seals? If it has split it won`t freeze 100% as
    warm air will get in and keep the temperature up, bit like leaving the
    door slowly open.
My refrigerator is warm but the light inside turns on and i have it set to cold, it just stopped working today
Have you unplugged the fridge sir? checked for any electrical disconnections? dust clogging your tubules in the back? Enough space between the wall and fridge in the back? sometimes these will do it. Your fridge needs air to oxygenate the tubules so that it does not overheat and not work.
Jan 07, 2014 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
Beko CDA543 F freezer always on?
noise sound like compressor mount are loose or rubber garment fell off that stops vibration or pump is bad internally call warranty get replaced if not a mounting problem of compressor
Mar 02, 2017 | Freezers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Freezers Logo
315 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
